Steering stabilizer for 109 designa chassis and RRC axles - Defender Source
Old May 14th, 2014, 11:03 AM
WildBoar's Avatar
WildBoar
Derek Borror
109 withdrawals filled by a 110
I think it is time to explore this option to support my manual steering. Not sure how to approach getting a stabilizer that will work with my set up. Looks like the chassis is configured to bolt in but I am not sure about the rest of the steering set up. Any Recommendations on brand or even size?
ID:	94903   Click image for larger version
"I think we are good...its still dripping"
Old May 14th, 2014, 11:11 AM
I would think you would want to go with (1) a disco steering stabilizer behind the front axle or (2) convert the drop arm to D90 style and run a D90 steering stabilizer.
If you don't offroad a lot, I would go with (1) as it will be basically free for the parts used.
Old May 14th, 2014, 11:54 AM
WildBoar's Avatar
WildBoar
Derek Borror
So this set-up from a Disco?
Old May 14th, 2014, 11:58 AM
WildBoar's Avatar
WildBoar
Derek Borror
And not this aside from any reason but the price?
Old May 14th, 2014, 12:09 PM
I would do the second choice (Defender damper to Disco tie rod conversion) if you are going off road.
Old May 14th, 2014, 12:48 PM
WildBoar's Avatar
WildBoar
Derek Borror
Not sure how much off roading is in this old girl's future.
Old May 14th, 2014, 01:28 PM
LR Max
Thomason, Max
1973 Series 3 109
I've been researching this. There are a number of generic kits for sale that I think will work just fine. I saw one on Amazon, its a Monroe steering stabilizer with a bunch of hardware (including what you need to attach to the drag link). This is the direction I plan on going.
Old May 14th, 2014, 02:47 PM
WildBoar's Avatar
WildBoar
Derek Borror
Can you share that link please?
Old May 14th, 2014, 03:39 PM
I don't like clamps on the drag link personally. Disco I is pictured as above would be best for street use.
Old May 14th, 2014, 03:45 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Any reason why? I am going to sleeve a stock Disco cross link and then weld a bracket for the steering stabilizer. Should look cleaner than a clamp and I get to use TRE vs the dropdown ball joint that seems to rip rubber boots on the Defender setup.
Old May 14th, 2014, 03:46 PM
For street use, there is really no point to having a damper. It will just make the steering heavier. The only real use of one is for preventing the steering from snapping hard off road.
Old May 14th, 2014, 04:28 PM
Welding on makes fine adjustment of allignment tough. Maybe I am biased because I found they slipped, but I am not a fan of the clamps. I also am biased in favor of stock because that is just how I am.
Old May 14th, 2014, 06:09 PM
LR Max
Thomason, Max
1973 Series 3 109
Little trick I learned from the rock WEROCK guys: put some locktite on the U-bolts that attach to the drag link. Seemed to help them with the early double ended hydro rams (originally they were smooth and sometimes would slide instead of move the wheels). I know it sounds like snake oil, but it made a huge difference.
I'll dig up the link when I get home.
Old May 14th, 2014, 06:32 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
:smackshead: I didn't even think of that. I will sleeve it and make a bracket for it or get one of the RTE ones. I would usually just get a Defender one but have read that the Disco/TRE last longer. After replacing my drop arm link twice on my NAS I can see this being the case.
------ Follow up post added May 14th, 2014 06:35 PM ------
Mmm, I may not run one after the build is done and am street testing it. Then just wait until I go off road.
Old May 14th, 2014, 07:28 PM
WildBoar's Avatar
WildBoar
Derek Borror
I am trying to identify the bracket on the right side of the stabilizer. Is that from a RRC or a disco?
Old May 14th, 2014, 09:18 PM
WildBoar's Avatar
WildBoar
Derek Borror
Never mind. Look what the magic parts bin contained!
Old May 15th, 2014, 10:08 AM
WildBoar's Avatar
WildBoar
Derek Borror
What length of stabilizer do you think this is? Definitely a Disco 1 right?
Old May 19th, 2014, 01:25 PM
WildBoar's Avatar
WildBoar
Derek Borror
Got it - LAND ROVER STEERING STABILIZER DAMPER STC786
Steering stabilizer? D90 to d1 steering. Arcadeus Defender Technical Discussions 2 May 18th, 2013 09:53 PM
Britpart shocks and steering stabilizer willr For Sale - Parts 0 January 10th, 2013 09:11 PM
109" Designa Coil Chassis and running gear dieselrover For Sale - Parts 4 November 6th, 2008 07:22 PM
steering stabilizer jimmy salmon For Sale - Parts 0 May 10th, 2005 12:44 PM
Steering Stabilizer...will it help? P1CR Defender Technical Discussions 11 November 26th, 2003 01:55 PM
