Starter for Lightweight - Defender Source
Old April 17th, 2013, 10:40 AM
kjva
Ken Jackson
1985 110 Wagon
I need starter for my 2.25 Lightweight Series 3 1977, spoke with the UK and a recon OEM starter is around 260 UK pounds plus shipping.
I do not want repro crap so looking at British Starters or Mean Green.
Any pros and cons from anyone actaully using them ?
Old April 17th, 2013, 10:49 AM
gambrinus
Russ Wilson
1965 Dormobile
How bad is your current unit? I've had good luck with having starters and generators rebuilt... IF you can find a good local shop that can still do it.
Old April 17th, 2013, 11:23 AM
kjva
Ken Jackson
1985 110 Wagon
I took off the starter to put on another Rover I sold recently.
Old April 17th, 2013, 01:55 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I've only used the V8 version from British Starters. No issues.
Post on Guns and Rovers. Odds are very high someone has a good one they'll sell.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old April 17th, 2013, 03:25 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
We probably have some good used ones around.
Last one we sold went for $100 + shipping.
I can check for one of you have interest.
RDavisinVA
Old April 18th, 2013, 07:57 AM
I have one from British Starters in my series. I was very happy until it got below freezing and would no longer start, but it's possible I have a problem external to the starter. Words fine as long as it's a bit warmer.
Originally Posted by pendy
I'm here for the D's
Old April 18th, 2013, 11:28 AM
Any starter should be able to turn over a 7:1 or 8:1 2.25 petrol motor.
Old April 18th, 2013, 11:40 AM
kjva
Ken Jackson
1985 110 Wagon
Thanks for the info I have noticed in my Series Rovers the starters seem to vary in turning speed.
The 2A LWB wagon spins very quickly but the 2A SWB spins much slower.
As mentioned in another thread I had one which always turned like the battery was low.
Old April 18th, 2013, 11:42 AM
Probably a bad ground if it is doing that. The mesh type ground wire is prone to corrosion.
Old April 18th, 2013, 11:48 AM
kjva
Ken Jackson
1985 110 Wagon
No I replaced everything from battery, cables, solenoid, cleaned the ground added an extra earth to no avail still the low battery / sluggish turning.
Took the starter off the Lightweight and fitted it to the S3 and it turned fine.
Hence the need for a starter for the Lightweight
Old April 18th, 2013, 12:04 PM
In my case it wouldn't even click when cold so I think the solenoid is suspect. But I'll check the grounds. I bought a rebuilt kit which is damn near everything but the housing so will likely do nothing till next winter and then freeze my ass off rebuilding/replacing it, or just hand crank it like I did this year
ht, start, starter
Starter issues on my D90 Rover- Girl Defender Technical Discussions 13 February 13th, 2010 10:59 PM
Wobbly distributor cap? and an update on my starter problem MiniGuy Defender Technical Discussions 6 January 10th, 2006 10:13 AM
Compatible starter motor question? MiniGuy Defender Technical Discussions 14 January 3rd, 2006 10:58 PM
Starter solution for TD D90? torque Defender Technical Discussions 0 April 30th, 2005 11:10 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
