Sluggish starter in Series 3 - Defender Source
Old December 20th, 2012, 04:20 PM
kjva
Ken Jackson
1985 110 Wagon
Have a 5 door Series 3 Station Wagon which I hope to sell at some point.
One thing which irritated me was the hesitant starter motor which always turned like the battery was low.
I checked the ground, put it a new battery and solenoid plus new cables still the same. Even ran a ground from the battery negative to the starter body with jumper cables.
Switched the starter from another Rover and the problem was solved.
It was a UK made starter with no name on it, came with the donor vehicle for the Station Wagon body. I had a friend who rebuilds starter for dozers and the like look at it and he could see no problem.
Old December 20th, 2012, 04:40 PM
I have one of those starters from britishstarters.com in my series and it works great. Mine didn't have the same symptoms as you describe before replacing it, but the new one definitely spins faster.
Originally Posted by pendy
I'm here for the D's
Old December 22nd, 2012, 10:00 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I like the Denso's from British starters. All I'd suggest is a spare set of contacts for the solenoid as that's about all that goes wrong with Denso's.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old December 23rd, 2012, 08:50 AM
kjva
Ken Jackson
1985 110 Wagon
Will try a Denso I took the starter off the Lightweight as we broke a half shaft.
After the cost of a Detroit rear end from GBR the starter is a drop in the bucket.
Old December 23rd, 2012, 01:55 PM
broadstone's Avatar
broadstone
'84 CSW 90 '74 NADA III '97 CSW 110
About 4ish years ago I purchased what was called a rebuilt starter from Rovers North. Because it went into a rebuild I did not use it until one and a half years after purchase. Maiden voyage it left me stranded, it cranked but very slowly and got very hot. I checked everything else and then it left me stuck 3 more times until I put a used starter in and never had a problem again. Of course the warranty did me no good since I did not install it right away. Anyone want to buy a rebuilt starter used about 4 times?
Patches are for Pirates and pants, not a bulkhead and chassis!
series, start, starter
Series Parts Scored from Lybia SafariHP The Vendors Loft 0 March 5th, 2011 07:54 AM
Series II Starter wanted ROVERMAN1 Wanted 0 August 21st, 2010 07:39 PM
Compatible starter motor question? MiniGuy Defender Technical Discussions 14 January 3rd, 2006 10:58 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
