Sluggish acceleration, loss of power on Td5 - Defender Source
Old August 20th, 2015, 06:22 AM
apras77
Achill
1999 Td5
Hi all,
since a few days, suddenly, my Td5 has lost its power when accelerating. The Nanocom analysis brought the following results. B
FAULT 09-05 turbocharger wastegate open load (current)
FAULT 09-06 EGR inlett throttle open load (current)
FAULT 13-05 turbocharger wastegate short circuit (intermit.)
FAULT 13-06 EGR inlet trottle short circuit (intermit.)
Besides the power loss, everything works smooth. No smoke, no alarm lamps in the cockpit, etc.
What is the problem here? Has anyone a hint what needs to be done?
Achill
Old August 20th, 2015, 07:27 AM
Biggest problem we're going to have here is that this is mostly a North American forum with very little Td5 experience.
Old August 20th, 2015, 09:02 AM
Speak for yourself Chris.
Looks like you have an early one, with that many faults have you checked your engine loom for oil ingress, it was an issue for the first couple years of production ? Many of the early trucks had oil work its way all the way back to the ecu and short things out. Also if the egr vave sticks open you loose all power. I'd start there.
Td5's are known for eating turbo's do you have any way of measuring how much boost you are making ?
Old August 20th, 2015, 10:04 AM
apras77
Achill
1999 Td5
Thanks.
I had the oil problem a few years ago. The engine went into 'emergency mode' with a speed max at about 60mi/h. It feels very different this time.
Think the EGR is making problems. I read that the engine can also run without it. Could I just remove it with an EGR blanking kit?
Old August 20th, 2015, 06:46 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Try posting on here too..... lots of TD5 experience there Land Rover UK Forums
Old August 20th, 2015, 11:32 PM
myoverlandrover's Avatar
myoverlandrover
josh
109
Originally Posted by apras77 View Post
Thanks. I had the oil problem a few years ago. The engine went into 'emergency mode' with a speed max at about 60mi/h. It feels very different this time. Think the EGR is making problems. I read that the engine can also run without it. Could I just remove it with an EGR blanking kit? Thanks
Yes remove egr and just use a kit to cover it. Will throw a code on the nano but won't effect its operation. That's a cheap place to start and see if that clears up your issue.
Defender 110
ac, td5
'97 no power upon acceleration, backfire at intake bamanuke Defender Technical Discussions 62 October 11th, 2015 05:42 PM
Sluggish uphill standard 2.5 diesel engine Stephen Fitzgerald Defender Technical Discussions 11 September 14th, 2014 02:38 PM
Sluggish starter in Series 3 kjva Series Technical Discussions 4 December 23rd, 2012 01:55 PM
Sluggish starting tdi mikeslandrover Defender Technical Discussions 15 February 17th, 2010 04:17 AM
sluggish power and keeping cabin cooler stever Defender Technical Discussions 3 April 22nd, 2005 12:53 PM
