Should I swap engines? - Defender Source
Old July 10th, 2015, 02:20 PM
newbie
1980 Series III 109 Diesel
I have a Series III 109 with a 2.25 L NA three bearing in it and of course he's as pokey as a turtle. I'd like to get him where I can get him to 55 easily on Overseas Highway. The engine is great actually but I'm tired of one finger salutes. Any advice? 200 TDI? 300? Is my current engine worth anything in a swap?
Thanks.
Old July 10th, 2015, 07:28 PM
Ncrover725's Avatar
Ncrover725
Bobby
1985 110
I would say 200tdi might be the best bet.
Bobby
1985 110 5 Door
1991 90
1998 D1 (Sold)
1971 109 3 Door (Sold)
Old July 10th, 2015, 07:58 PM
200tdi and go the whole hog with a 5 speed as well.
Old July 10th, 2015, 09:25 PM
phoenix37's Avatar
phoenix37
john
get an overdrive and one of these stickers and call it a day...
Key Largo Oval Decal by dontmakememad
Old July 10th, 2015, 09:31 PM
newbie
Loving the sticker! Grew up in Tampa - had the "I-75 goes both ways" and "We don't care how you did it up North" stickers on the cars.
Old July 11th, 2015, 10:08 AM
newbie
Thinking that overdrive will be the ticket. I don't want to spend a mint (this truck is a pure toy and won't be restored (I already made that mistake with another vehicle and was afraid to take it off road). My soon to be 16 yo wants to drive it because his friends think it's cool - another reason not to restore him as he might end up in a few scrapes.
Old July 11th, 2015, 10:22 AM
Departing90
Sasha
95 D90
No offence but if your 16 year old is about to drive a tank you may consider keeping the same engine. If you do decide to swap I'd be interested in it.
Old July 11th, 2015, 10:26 AM
newbie
Yeah I really don't want to swap engines, I just need the vehicle to be able to get up to highway speeds in a reasonable amount of time, which down here is 55 mph.
Old July 11th, 2015, 10:45 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I was somewhat in your situation late last year and I'm currently going through the swap process. I started by buying an engine, trans and tcase to replace an original 2.5na drive train. My "plan", based primarily on what I had read up on, asked around and observed from other's stories, was to simply pull the old and do a straightforward bolt-in install. The reality, which is tough to see when you are wrapped up in all the bromance, is these are old lumps, there are no guarantees so it feels a shame not to refresh many many things before it goes back in. Nobody will be holding a gun to your head to replace stuff but if you don't you might just shoot yourself later. Using nice round numbers, if $10k is a number you're comfortable with then you should do it and if you blow the budget by 10%-20% just drive it more and enjoy it longer.
Clay
Old July 11th, 2015, 10:56 AM
newbie
$10K is not in the cards right now, not with my husband's boat. I'm kind of liking the overdrive idea.
Old July 11th, 2015, 11:05 AM
2.25 diesel may not be able to pull that truck with the taller gearing of an overdrive. Lack of torque/power is your problem not gearing. 2.25 diesel was a horrible engine in the best of times, 40 years later....
Old July 11th, 2015, 11:08 AM
newbie
Part of my fears... I may just continue to tick everyone off then. Overseas highway is a parking lot on the weekends anyway. Not going anywhere very fast.
------ Follow up post added July 11th, 2015 10:11 AM ------
Uncle Douglas, what should I drop in him? I'm totally against going petrol.
Old July 11th, 2015, 11:26 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
The overdrive isn't going to give you more power, only lower engine rpm at any given speed. It's not going to help acceleration or maintaining a speed after you eventually get there as your limiting factor will be the power available from a na diesel engine.
The lesser expensive option is likely going to be fitting a 2.25/2.5 gasoline engine with a little more cam and more carb, but as you mentioned you are not fond of gasoline... I guess that leaves you with fitting a 200TDi!
Email is
Same place, new dogs.
Old July 11th, 2015, 11:28 AM
newbie
Thanks for the insight. Will a 200tdi fit to my tranny or am I basically looking at a new drivetrain?
Old July 11th, 2015, 11:32 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
How nice is your 109...what is it worth?
Rent my
At this point, why not go for a Chevy V8 swap and Nick's adapter?
Old July 11th, 2015, 11:44 AM
newbie
I got rid of my gorgeous CJ7 because of the V8. He's not that nice, maybe worth $7000 at most right now. He's pretty solid, but not fixed up.
Old July 11th, 2015, 01:05 PM
1of40's Avatar
1of40
1of40
Keep it original. Pay someone to replace all the worn bushings, shocks and springs. Have the wheels repainted and put new tires on her. Give her a proper tune up and I bet you'll fall in love all over again.
Old July 11th, 2015, 01:10 PM
newbie
I love him, just would like him to cruise a little better
Old July 11th, 2015, 02:42 PM
phoenix37's Avatar
phoenix37
john
Apologies if i gave you bad advice about the OD. I only have experience with the gas 2.25l and an overdrive made a big difference if you want to cruise at 55-60mph without trying to push the gas pedal through the floor. I stand by the sticker recommendation though!
engine
Until I swap engines to an EFI... samer0214 Defender Technical Discussions 22 December 1st, 2014 09:15 AM
Carb rebuild vs FI swap vs engine swap samer0214 Defender Technical Discussions 14 July 13th, 2014 08:33 AM
Should I swap out my heater mattarm Defender Technical Discussions 4 April 23rd, 2014 09:00 AM
Viscous Coupling swap - anything I should know? Emerson00 Defender Technical Discussions 1 December 10th, 2007 10:24 AM
Tell me why I should/should not buy a D90 fustogrande Defender Technical Discussions 44 March 2nd, 2006 11:57 AM
