Should I swap engines? - Page 3 - Defender Source
Old July 12th, 2015, 01:27 PM
newbie
1980 Series III 109 Diesel
Those huge tires were on him when I got him.
Old July 12th, 2015, 01:36 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Example scenarios. As others have said, going to a smaller (and more appropriate sized) tire will make a noticeable difference in gearing, rolling friction, unsprung mass, mpg, braking and acceleration. All to your advantage. It is a no-brainer decision.
ID:	124860   Click image for larger version
Old July 12th, 2015, 02:04 PM
235 85 R16 (or 7.50 x 16) tires on flat ground you should be able to do 55mph.
------ Follow up post added July 12th, 2015 02:06 PM ------
Also, you are going to be at too high of an rpm in a diesel with tires much smaller than what I mentioned above. Plus, on a 109 they will look stupid. You should also check to be sure you do not have a "1 ton" 109 as those had steeper transfer case gears.
Old July 12th, 2015, 02:15 PM
phoenix37's Avatar
phoenix37
john
completely off topic but if you are going to keep calling it him you might as well give it a name!
Old July 12th, 2015, 02:51 PM
newbie
Lol - his name is Jack. Named him before he was even titled to me.
Old July 12th, 2015, 02:57 PM
BlackField's Avatar
BlackField
Oscar
D110
Jack might become Jacqueline if you snip his big rollers.
Old July 12th, 2015, 03:22 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
OOOH, I have something to offer: I bought a set of 5 General Grabber AT2 in a 235/85 16 for a job I was doing, and meant to order a different size. They are brand new. It would have cost me $110 to ship them back to the supplier, on top of the original $110 to ship them in. If that is a size you want to consider, let me know and maybe make an offer?
Email is
Same place, new dogs.
Old July 12th, 2015, 03:53 PM
newbie
You sound like my son Blackfield!
Old July 22nd, 2015, 08:35 AM
lennix's Avatar
lennix
Lennie
1993/Defender Tdi200
My obvious choice would be the Tdi200 for power and economy. However, an often overlooked second option would be the 2,5 TD (J19), providing that you can find one in decent condition. For one the engine is less noisy than the Tdi200 and also it would be less critical that you upgrade your drivetrain and brakes.
engine
Until I swap engines to an EFI... samer0214 Defender Technical Discussions 22 December 1st, 2014 09:15 AM
Carb rebuild vs FI swap vs engine swap samer0214 Defender Technical Discussions 14 July 13th, 2014 08:33 AM
Should I swap out my heater mattarm Defender Technical Discussions 4 April 23rd, 2014 09:00 AM
Viscous Coupling swap - anything I should know? Emerson00 Defender Technical Discussions 1 December 10th, 2007 10:24 AM
Tell me why I should/should not buy a D90 fustogrande Defender Technical Discussions 44 March 2nd, 2006 11:57 AM
