Shallow bucket headlights - Defender Source
Old March 1st, 2011, 12:56 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I'm looking for some 7in headlights that are shallower than most. I'm already goign to chop the bucket but I need more room.
I need every inch of the room behind the breakfast for radiator/intercooler.
The trucklite LED's are shallow but are $$$$$.
any suggestions?
Old March 1st, 2011, 01:14 PM
put on an SVX type front and mount the headlights further forward.
Old March 1st, 2011, 01:34 PM
You can run without full buckets. First, DONT CHOP THE NICE ORIGINAL BUCKETS. Second, go find a RRC and take the buckets out of it. The have no backs already.
All lights seem to be about the same depth to me other than, as you mention, LEDs. I have seen right angle plugs which might help a bit (or just use three individual tabs rather than the full plug).
Old March 1st, 2011, 01:59 PM
D90user's Avatar
D90user
steve
SVX?? this is for a series 1.
I'm not moving the breakfast. My goal is to keep it original looking from the outside.
Ron- I have a set of donor buckets from a 2a to chop... but It looks like I'm going to be chopping the rear of the breakfast regardless. I've already stepped off the edge and chopped the motor mounts.
Side mount plug may just do the trick. The plug is an extra 1-1.5 inches when attached.
I'll look in to that.
I thought about bending the tabs and going 3 individual plugs... but it is nice to have a socket.
Old March 1st, 2011, 02:13 PM
Sockets such. They overheat and melt. Other than making sure you hook them up right, IMHO individual plugs are better.
Old March 2nd, 2011, 01:24 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
I used the early RR buckets on mine with aftermarket plugs. plugs have the wires coming out at a 90 deg angle.
ht, lights
Low Beam Headlights Quit JimC Defender Technical Discussions 7 January 29th, 2006 07:54 PM
Headlights - switch problem? mgrgpg Defender Technical Discussions 3 December 14th, 2005 03:42 PM
My headlights are not working woldd90 Defender Technical Discussions 13 December 2nd, 2005 10:49 AM
2 Defender headlights Disco_Stu For Sale - Parts 5 September 28th, 2005 11:59 AM
Yaaaaaaaaaaaarg! Frigging headlights solihul Defender Technical Discussions 2 June 23rd, 2005 10:29 PM
