series v8 build help - Defender Source
Old June 30th, 2010, 11:36 PM
orionpco
larry burns
1962 series 2a
ok, i have a 3.5 (being rebuilt with alot of good advice from d & d fab) rover v8 to series trans adapter (milner) a r380 being converted to a short bell housed version (ashcroft trans- kit)
Question #1
what im missing here is which flywheel and clutch set up do i use with this setup?
Question #2
i have both uj and cv axles i could use in this project and could use the series tc or the lt230 tc, any advice to which one i should use?
Question #3
what in the hell possed me to get ass deep in this endeaver?
Old July 1st, 2010, 07:14 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
1. Early Range Rover flywheel and clutch.
2.W/ Series TC you get easy 2wd and is plenty strong easy to deal with. The LT230 will fit the R380 w/o adaptor. I'd go with the LT230. Use regular UJ driveshafts unless you have some unequal angles to deal with and are worried about vibrations.
3. It's well known that I ask myself this question multiple times daily so probably not qualified to answer.
I have done this conversion and have many photos if you need some visual aid.
Matt Browne
Old July 1st, 2010, 07:21 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
That's what the motor part looks like
ID:	28971   Click image for larger version
Matt Browne
Old July 1st, 2010, 08:15 AM
orionpco
larry burns
1962 series 2a
bring on the pics
Old July 1st, 2010, 11:21 AM
Matt, I think he was talking about axles, not driveshafts.
Old July 1st, 2010, 07:56 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
right. well then.....CV axles for the LT230. UJ axles for the Series TC or convert the LT to part time 4wd for the UJ axles
Matt Browne
Old July 1st, 2010, 08:18 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
The donor lump from an '84 RR 2 door. Same lump cleaned up and fitted with the front end and anciliaries from '94 Defender.
Name:	Copy of P8300240.jpg
ID:	28986   Click image for larger version
Name:	Copy of P8300241.jpg
ID:	28988   Click image for larger version
Matt Browne
Old July 1st, 2010, 08:29 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
Firewall modified to clearance for cyl heads.
Custom 4 core rad built almost full width using end tanks from RR rad. The large brace rad is mounted to is the crossbar for the front shocks (another story)
Used original oil cooler.
Used engine driven fan......I strongly dislike the use of electic fans unless no other option.
ID:	28990   Click image for larger version
ID:	28992   Click image for larger version
Matt Browne
Old July 1st, 2010, 09:30 PM
Is that tonka?
Old July 2nd, 2010, 07:18 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
Yes indeed. I have joint custody.
Matt Browne
Old July 2nd, 2010, 08:33 AM
Do tell. I'm fascinated by these kind of conversions. I assume coil over too then?
Old July 2nd, 2010, 03:00 PM
I don't have personal experience with this, but I looked into it for my SI and what I would do is run the u-joint axles and the series T-case (in the stock location) with the ashcroft adaptor to the LT77. It seems the easiest by far. If you run an LT230 with a u-joint axle, I would put an AVM part time kit in the T-case.
The biggest problem with running the coil axles on a series is the leaf spring wants to be in the same spot as the steering link.
Running an LT230, my understanding is that, the driveshafts are custom and will hit the one transmission.
I know it is another spendy adaptor to run the series T-case but I think it makes it the cleanest.
FWIW YMMV never was far enough in to try it etc.
link to ashcroft conversion kit which has an internal link to the AVM part time LT230 kit
http://www.ashcroft-transmissions.co...d&productId=83
Old July 3rd, 2010, 06:40 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
Yup, I said run the LT230 but in reality other than it bolting to the R380 I'm not sure why. I wouldn't run coiler axles unless the build was really going over the top and you need room for very large tyres and are prepared for a pile of work.
Regardless of the T-case used when adding an R380 or LT77 the driveshafts are going to be custom (if you'd retain the Series front clip) as the t-case will need to be moved about 4" back. It also needs to be lowered a bit or the driveshaft will bind.
Matt Browne
Old July 3rd, 2010, 06:48 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
No coil over, just really long Pro comp 9000's. Does have power steering (Toyota and OE custom bits) and Volvo Portal axles.
Some pics of mondo beef steering arms (yup, my photo skilz suck)
ID:	29020   Click image for larger version
Matt Browne
Old July 3rd, 2010, 03:06 PM
I believe there is 4in of room to move the engine forward. The way I have seen it done is to trim the back of the breakfast and move the radiator forward.
Old July 5th, 2010, 07:11 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
That works with an SIII where the headlights are not an issue and if you are using the 4cyl.
The V8 requires moving the radiator forward about 4" if the bellhousing stays in the same spot. If you add the R380 to the length you'd have to go back. You might be able to gain a couple of inches somewhere if you want to use 'lectric fans.
Matt Browne
Old July 5th, 2010, 07:23 PM
orionpco
larry burns
1962 series 2a
well as far as im concerned, moving the radiator forward is no problem and using electric fans is advantageous. from what i can tell at this point i will be moving the rad forward and lose an inch to an inch and a half of drive shaft length. an inch or two of shaft length should be easily handled with a double cardon shaft. what im concerd about today is the center shock like device on my rrc donor axle and whether or not i need it. any thoughts?
Old July 5th, 2010, 08:09 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
you don't need it.
Matt Browne
Old July 5th, 2010, 09:27 PM
He has a short shaft R380, not the V8 R380. I think it should fit (V8 R380 would require the defender front end). The V8 and the short shaft R380 with the adaptors is not much longer than the stock drivetrain.
Ron
Old July 6th, 2010, 03:08 AM
orionpco
larry burns
1962 series 2a
the r380 is a defender v8 unit, with the ashcroft stumpy kit. should have possion of the r380 by the week end. scary times will it work or will it not ? i will let you know soon
series, v8
Coil Series truck build TDI Guy Truck Build-up's & Restores 111 April 27th, 2013 11:15 AM
Conatiner Arrival means Defender / Series Parts Clean Out SafariHP The Vendors Loft 18 December 5th, 2008 09:38 AM
Looking for series Help Dfndr90 Misc. Chit-Chat 4 January 1st, 2005 12:50 PM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 01:04 AM
