Series Tranny Fluid? - Defender Source
Old August 2nd, 2011, 10:53 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I'm away from the workshop manual and a computer. What's the recommended fluid for Series I trannys?
Semper Fi!
Old August 2nd, 2011, 11:16 AM
GL4 gear oil. NOT GL5 it eats the yellow metal. How are you posting if you are away from a computer?
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Isn't the same as for SII, 75-90 wt?
Old August 2nd, 2011, 12:28 PM
Wolf Fabrication
Sterling Archer
'08 D3
Yeah, I thought it was just normal gear oil?
Semper Fi!
Old August 2nd, 2011, 12:35 PM
kevkon's Avatar
kevkon
kevin
Ron is right about the GL-4. I personally like the Amsoil for that reason.
Old August 2nd, 2011, 05:23 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Rumor has it that the newer GL5 formulations don't eat the yellow metal like it did when GL5 first came out.
At least that's what Castrol Heavy Duty (formerly Drydene) told me when I rang them. YMMV.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 3rd, 2011, 11:16 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I have heard that GL5 with an MT1 designation is safe for brass. True?
I'd rather run a modern oil... as long as it does not just leak out
Old August 3rd, 2011, 01:49 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Well, I was second guessing myself so called Castrol and they said their GL-5 is not recommended for units that have yellow metal. Though the person didn't seem to be speaking with confidence, so another call later may get a different answer. I guess to be safe, stick with GL-4. Which is difficult to find in dino oil.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 3rd, 2011, 03:49 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
You would think they'ed have a fact sheet in front of them.
Old August 3rd, 2011, 04:25 PM
kevkon's Avatar
kevkon
kevin
It's a very confusing subject and I suspect the oil companies like keeping it that way. Basically it comes down to the EP additives used in both GL4 and GL5 and what corrosive effect they have on yellow metals. GL5 has more EP additives but it still is almost impossible to find out just how corrosive these additives are unless the oil company specifically provides a test result.
Here is what Mobile says
Question: Gear Lube Effect on Transmission Brass ComponentsIn regard to the Mobil 1 Synthetic Gear Lube LS 75W-90 Gl-5 LS gear oil. Does the statement "Excellent rust, staining and corrosion protection of copper and its alloys" mean that the additives in the product will not eat away at the brass components in the gears of the manual transmission of my 1998 Pathfinder?-- Tony Fasolino, Columbus, OH
Answer: Nissan recommends a GL-4 type gear lubricant for your Pathfinder. Mobil 1 Synthetic Gear Lube is an API GL-5 gear oil and would not be recommended for your manual transmission.
Old August 3rd, 2011, 08:01 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Exactly.
I ran Drydene/Castrol ESGL 85W140 GL-5 in my Series Rovers for 10 years or more with no noticeable ill effects (before I knew about the supposed risks of GL-5), but I'd never suggest someone else do that because of all the claims of GL-5 eating yellow metal.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
series
What fluid for a lt85 tranny draaronr Defender Technical Discussions 19 May 10th, 2012 01:20 PM
Series I Tranny Wanted Wolf Fabrication Series Technical Discussions 5 July 18th, 2011 10:01 PM
Series Tranny Question Wolf Fabrication Series Technical Discussions 1 June 27th, 2011 12:21 PM
