Series Timing Questions What the heck - Defender Source
Old June 26th, 2011, 02:32 AM
bstraw's Avatar
bstraw
Byron Straw
1994 POE/ST
So I have been reading the "green bible" about timing the 2.25 without front marks as I am putting in a new 2.5 cam. In a book that deals with tolerances of one thousands of inches, I am stumped at this. Please see the photo I posted at (https://picasaweb.google.com/byron.s...07884092503026) to understand what I am talking about, you may need to click the "full screen" tab to be able to read it. Ok, here is what I do not understand; let's start with #8 in the photo. "turn the camshaft in the direction of rotation until the rocker pad has nearly opened the valve fully." What the heck, WHAT DOES NEARLY OPENED mean. How do I know when to stop? Additionally, is the point of the operation to get the #1 exhaust valve fully open? If you have a dial indicator, why would you need to go through the NEARLY fully opened option. My "nearly opened" may be different than the next guy's so how does this method make sense when you are just trying to find the maximum (open-ness) of the #1 ex. valve. Am I completely missing something here? Am I just dumb , or can I just use the dial indicator to set the #1 ex. rocker to the maximum full position and then set the crank, and then put the chain on? Sorry for the confusion but I do not want to take the front cover off after I have the motor in. I have looked at the "Land Rover FAQ" and I am still confused. Why would they say "Nearly." Ahhhhhhhhhhhh!
Old June 26th, 2011, 06:25 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
That's quite common when building motors. I read that at setting the cam lobe right before it's apex on the exhaust valve. There is really no way to put a measurement on this due to varying tolerances on parts.
Semper Fi!
Old June 26th, 2011, 09:06 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
The way to find absolute TDC is to go in one direction until movement has stopped make a mark, then rotate in the opposite direction and make a mark. Halfway between those two marks is tdc.
Old June 27th, 2011, 12:36 PM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
X2, that's how I've done it.
series
Series III Questions CMS3900 Series Technical Discussions 3 February 12th, 2011 10:22 PM
Series III Import Questions TanzaniaSafari Series Technical Discussions 2 February 3rd, 2009 12:26 AM
Ing timing? Series III. oldgreentrucks Series Technical Discussions 1 March 27th, 2007 11:16 AM
Series III Cam Timing ... bossongs Series Technical Discussions 0 April 30th, 2006 05:11 PM
