Series roofs? - Defender Source
Old October 9th, 2016, 10:06 AM
terryjm1's Avatar
terryjm1
Terry
1988 Land Rover Santana & 98 D1 TDI
Series roofs?
My fiberglass roof needs a patch and has some other wear and tear. Is there a new replacement out there for Series 3?
Thanks in advance!
Old October 9th, 2016, 10:09 AM
rovertrader's Avatar
rovertrader
Dale
I have a like new Series roof, as well as an old cheap one.
Old October 9th, 2016, 12:16 PM
terryjm1's Avatar
terryjm1
Terry
Roofs
Photos, price? PM if you prefer.
Terry
Old October 9th, 2016, 12:31 PM
Greg S
Greg Sutfin
1986 90
If it's fibreglass then it is probably not a Series 3 Land Rover. Do you have a Santana maybe?
If a Santana, I think the roofs don't interchange with Land Rover.
Old October 9th, 2016, 12:35 PM
terryjm1's Avatar
terryjm1
Terry
Yep
It is a Santana and I am hopeful a Series 3 will interchange. It has an 88" wheel base and has a Series 3 tub. I am hopeful it will interchange as logically it should. All the other "tub" related stuff interchanges. Anyone know for sure?
Old October 9th, 2016, 02:20 PM
terryjm1's Avatar
terryjm1
Terry
Santana roof
That is true of the early Santanas, but not the 1988 model like mine. Have a look.
Old October 9th, 2016, 02:53 PM
rwollschlager's Avatar
rwollschlager
Rob Wollschlager
72 SIII 88
Which windshield do you have?
Worst case you can fit a series rover windscreen to fit a series rover roof, or defender windscreen to fit a defender roof.
Old October 9th, 2016, 03:12 PM
terryjm1's Avatar
terryjm1
Terry
Windscreen
I am fairly confident it is a Defender windscreen as it is not the split type. Did the late Series 3 have the split windscreen?
Old October 9th, 2016, 11:53 PM
Ignotus
gene
1960 109, w/200TDI
Some Land Rover owners removed the center frame part and put in 1-piece glass. So go by what Jeff said about it being above the side gutter level, or not.
Gene
1960 109
1960 88 Ignotus
Blog;
Old October 10th, 2016, 12:25 AM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
I didn't know the Santana roofs are fiberglass. It might be easier to repair that than source another. If it's an 88" then the sides aren't as long as 90 sides so I doubt the roofs are interchangeable. But if it has a Defender type windscreen then you can't just swap a series 88" roof over.
You little rebel, I like you.
Old October 10th, 2016, 06:53 AM
terryjm1's Avatar
terryjm1
Terry
Thanks for all the response!
For the time being I am going to peel the silicon off the puncture wound (dead branch from a Douglas fir) and apply a fiberglass patch while I continue to consider options for a replacement.
Seems the roof may be one of 5% Santana specific parts.
I really appreciate all the responses and the information shared has given me enough to answer the question.
Regretfully, the Santana is 1110 miles from me at the moment. However, here is a link to a recently ended eBay auction that shows what my roof looks like, It is short like the Series but has the Defender windshield.
http://www.ebay.com/itm/Land-Rover-D...m=252477590467
Old October 11th, 2016, 04:39 PM
Greg S
Greg Sutfin
1986 90
Fibreglass can be repaired and can easily be made to look original. Even if the whole tree had fallen across it, it is easier to repair than aluminum.
fs, roof, series
2.8 TGV, Non running 300TDI, Roofs, Tub/trailer. rherl For Sale - Parts 9 March 27th, 2015 07:52 PM
Late Series IIa or Series III wings fenders aka rover Wanted 7 May 11th, 2014 10:44 PM
WTB series 1 ton transfer case (or 1.53:1 gear set for series tcase) cgalpin Wanted 3 March 7th, 2013 08:54 AM
What Color are the door tops and roofs on 83 110's ? Uncle Douglas Defender Technical Discussions 10 September 3rd, 2012 07:22 PM
Series II or Series III door hinges which ones to run aka rover Series Technical Discussions 10 December 19th, 2011 03:17 PM
