Series Power? - Page 2 - Defender Source
Old August 12th, 2011, 07:00 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I have a 2.25 diesel five main bearing in my 110 that I keep thinking of replacing. If I had a potential buyer I would think even harder... Just had the head rebuilt a little while ago and it's my DD. 148k on the clock.
Old August 12th, 2011, 07:40 PM
Albersj51
jason
1967 2a
Google roverdrive gear corp in canada. They make new overdrives that I hear are more robust than the fairey units
Old August 12th, 2011, 07:41 PM
TeriAnn's Avatar
TeriAnn
Teriann Wakeman
1960 Dormobile
Originally Posted by JBinAlabama View Post
I'm mostly not a stupid driver...if that is what you meant
No, it is not you, it is just one of my pet peeves. Take a vehicle with a given mass traveling at a given velocity. It will take the same distance to stop using one set of brakes regardless of it having a 10 HP engine or a 1000 HP engine of the same vehicle weight. Yet everyone says "I'm going to put a bigger engine in it and therefore I need better brakes" . Drives me crazy. Because if you drive safely and within the speed limit it doesn't matter what engine is in it. My take is that if it is safe to drive 55 MPH with a 2.25L it is just as safe to drive 55 MPH with a 427 overhead cam. If it is unsafe with the big engine it is unsafe with the little boat anchor and you should have upgraded the brakes right away instead of waiting for an engine conversion to remind you that the brakes are unsafe.
That said, I will be adding disc brakes at the front......I was saving that question for later to tell the truth
It's an 88" and I may wait until we are finished but my brother said he will stick with the drums on his.
When the time comes I have a web page that you might find useful choosing a kit.
http://www.expeditionlandrover.info/discBrake.htm
I like SB fords, and I do have some parts on hand from my backdraft cobra.
I had not considered that the ford may be lighter than the 2.25
we basically have no hills in Alabama compared to the rest of north america
@kevkon, I have nothing against the 2.25 but one engine is in pretty darn bad shape and parts will likely be more than a used replacement
@anti.....WHAT?, I had not considered an overdrive, will check prices!
Everyone, what will the deduct in finished value be for having a non rover engine?
A whole lot depends upon how well the conversion is engineered and executed and who is looking at it for possible purchase. Land Rovers are the tinker toys of the car world and many are modified in different ways. There is a large group of people who will pay a premium for bone stock and a large group that will pay a premium for a well engineered and executed conversion. Timm Cooper is a well known fabricator who makes high quality conversions. I've seen some of his conversions sell for at least twice what a bone stock vehicle would go for. Good V8 conversions come with a much stronger drive train, well thought out gearing and power steering (gets the stock steering box out of the way). And I've seen some ratty poorly thought out conversions you almost could not give away.
A 200tdi conversion if well done would probably easily sell for more than a bone stock vehicle and a 2.5L conversion will usually make the truck easier to quickly sell. Most people can not easily tell a 2.25 from a 2.5 at a glance.
Bottom line is "It depends" upon a lot of stuff and a well done conversion does not mean a lower price to anyone who would consider purchasing a vehicle with a conversion.
------ Follow up post added August 12th, 2011 04:46 PM ------
Also look at the reproduction Santana units manufactured in the Netherlands by Paul Heystee
http://www.heystee-automotive.com
I know people who are putting them behind Escalade V8s in Land Rovers and are treating them hard. The Santana overdrive stands up to a V8 well (at least according to Tim Cooper and I've seen what he does to his).
While on the site, check out Paul's disc brake conversion kit. I think it is currently the best on the market.
TeriAnn
Old August 12th, 2011, 07:56 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
@Teriann: A heavier motor, especially over the front axle will increase stopping distance, that's simple physics. Just like a 3500lb Rover with stock brakes will stop faster than the same truck loaded to 4500lbs. So swapping in a 427 over a 2.25l will indeed affect braking.
Semper Fi!
Old August 12th, 2011, 09:16 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Also consider the diesel engine options. Diesels have little or no compression braking so there is an additional stress put upon the wheel brakes.
As far as how any of the non standard engine swaps will effect the value of a Series truck, I think that largely has to do with how well it is thought out and executed. Take a look at the SIIA 109 with the Cummins 4bt for sale on this forum as an example of a really well executed swap.
Old August 12th, 2011, 11:39 PM
TeriAnn's Avatar
TeriAnn
Teriann Wakeman
1960 Dormobile
Except I have not been talking heavier motor in any of my suggested offerings. I think all were within plus 100 lbs to minus 50 lbs. The 427 was just an example of a powerful engine not a suggestion for a swap. But Yes, any increase in mass or increase in velocity will require a longer stopping distance if braking remains constant.
It is just that it bugs me when people assume the ability to reach a given velocity quicker means you need more stopping power even if mass and crusing velocity remain the same.
TeriAnn
Old August 13th, 2011, 12:57 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Eh????
Mike Hammond
Old August 13th, 2011, 09:22 AM
kevkon's Avatar
kevkon
kevin
Unlike gas engines which use a throttle, diesels don't get vacuum braking when letting off the accelerator. Turbos can provide a little, but it is not the amount you get in a 4 stroke gas engine. It's the reason large trucks are often fitted with a Jake Brake.
TeriAnn, I understand what you are saying but I think that if one is going to up the performance of acceleration then it would be wise to do the same with braking. No, you don't have to, nor do you have to improve the handling (suspension). It would just be prudent.
Old August 13th, 2011, 01:58 PM
mikeslandrover
Mike Hammond
What about the 20:1 + compression ratio?
My 200tdi has more engine breaking than the V8 petrol ever had.
You need a vacuum pump for the power assisted brakes.
Exhauster pumps assist the wheel brakes as I understand it.
Mike Hammond
Old August 13th, 2011, 03:35 PM
kevkon's Avatar
kevkon
kevin
http://en.wikipedia.org/wiki/Engine_braking
And more to your point;http://www.hummerknowledgebase.com/engine/engbrake.html
It's all about vacuum
Old August 13th, 2011, 10:06 PM
mikeslandrover
Mike Hammond
Well I never
Mike Hammond
Old August 14th, 2011, 11:22 PM
Originally Posted by ArmyRover View Post
I saw a series III maintain 70mph with no overdrive for about 6 miles, shortly afterwards it sat in a parking lot spewing coolant....
Every once in a while someone does it, but they don't seem to be the same person afterwards.
My truck, no overdrive, and no spewing coolant when I stopped. Of course, I will admit this is generally only possible in the summer when the top is off - less drag.
ID:	41124   Click image for larger version
Old August 15th, 2011, 12:36 AM
TeriAnn's Avatar
TeriAnn
Teriann Wakeman
1960 Dormobile
Stock gearing & 32 inch dia tyres:
3686 RPM @ 65 MPH
3969 RPM @ 70 MPH
The 2.25L petrol is happy cruising in the 3200 - 3400 RPM range for long distance highway driving.
TeriAnn
Old August 15th, 2011, 08:46 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Yeah, I had the tilt & doors off when I drove from Cleveland to Madison.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 23rd, 2011, 10:10 PM
JBinAlabama
john
Series 2A ..more parts on the way
Thanks for all the pointers and tips folks!
I think we are leaning toward the 200tdi for ours and the 2.25 petrol for my brothers.
The 2.25 will be headed to the machine shop in the next couple of weeks.
Any suggestions on Springs and shocks?
I'm trying to get it all ready so that when the chassis & Bulkhead comes back from galvanizing we can make it a roller quickly to keep up the little guys interest
Old August 24th, 2011, 06:34 AM
Good luck with finding that 200Tdi.
Old August 24th, 2011, 07:49 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
?. Not exactly difficult.
Matt Browne
Old August 24th, 2011, 08:06 AM
Where to shop?
Old August 24th, 2011, 08:34 AM
Antichrist's Avatar
Antichrist
Tom Rowe
People seem to be fond of the parabolics as they offer a bit more travel, but I've always just used stock springs, though usually heavier duty than stock as I often seem to be hauling heavy loads.
For shocks I've used Rancho (I forget the part numbers), OEM and some from Nisonger that aren't available any more. I had them left over from when I used to be a Nisonger dealer.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 24th, 2011, 10:02 AM
Albersj51
jason
1967 2a
You can get them...Rover Resource, Land Rover Imports, ebay, etc. The price tag is a different story.
Where to shop?
series
Series Parts Scored from Lybia SafariHP The Vendors Loft 0 March 5th, 2011 07:54 AM
Series coiler to power steering conv? KevinNY Series Technical Discussions 20 September 9th, 2006 09:35 PM
Power Windows (was: Leccy Windows!!!!!) P1CR Defender Technical Discussions 21 February 28th, 2004 01:14 PM
