Series Oil Pressure Gauge Fitting Help - Defender Source
Old November 4th, 2011, 08:11 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
I am attempting to install a Smiths Dual Oil/Temp gauge. At the block there is a what appears to be a tappered female fitting, and the stock gauge line appears to be a flared female end. So I need some sort of male-male adapter. Anyone know the thread size of either?
Cheers!
Semper Fi!
Old November 4th, 2011, 09:06 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Are you asking about the oil line or the temp capillary? The oil, as I recall, is 1/8" BSP. The temp depends on which gauge you have and I can't remember the sizes. I think the females were something like 3/8" but I'm not sure, and I can't find my old Smiths catalog at the moment.
On a side note, I like the metal oil pressure lines better than the plastic ones. Though I've used both the metal ones make me less nervous.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 4th, 2011, 09:16 AM
Wolf Fabrication
Sterling Archer
'08 D3
Sorry, talking about the oil line. Whatever the thread size it, one is tapered and the other is flare fitting. I need some sort of male-male fitting.
Semper Fi!
Old November 7th, 2011, 12:27 PM
Can we quote you on that?
Old November 7th, 2011, 12:31 PM
Wolf Fabrication
Sterling Archer
'08 D3
Sure, feel free to add that to your signature line. I'll be here all day for your amusement.
------ Follow up post added November 7th, 2011 12:33 PM ------
And to close the loop on this, I just used regular American fittings and forced things to work, Everything seems to be holding just fine.
Semper Fi!
Old November 16th, 2011, 06:43 PM
Mark McDonough's Avatar
Mark McDonough
Mark McDonough
66' IIa, 95 D 90 300 Tdi, 94,98 D1
Through Bolt for banjo fitting
I'm working on the same part right now. My metal line ruptured somewhere just behind the dash before it feeds the gauge.....great. The part I think you need is a through bolt for the hole in the oil line you have.
series
low oil pressure at idle--sometimes cpk Defender Technical Discussions 5 February 7th, 2006 01:10 AM
1995 d90 no oil pressure bmwfastlyf Defender Technical Discussions 3 January 18th, 2006 03:10 AM
