Series III - Won't shift in to any gears - Defender Source
Old July 23rd, 2016, 11:07 AM
SeriesIII
J
1973 Series III
I have a Series III that has been a great runner the past 3 years. Today I went to take it for a drive and got a block from my house and wasn't able to shift it. Won't drive forward or reverse. Had to push it back home.
Checked the clutch fluid reservoir and it was full. Looked underneath and didn't see anything obviously disconnected
I need help from the forum to figure out where I should start the troubleshooting process to identify the problem.
Thanks!!!
Old July 23rd, 2016, 11:15 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Can't tell what is happening with your vehicle by the poor description.
Saying it won't shift means you can't move the gear shift leaver to put it in any gear and not sure that's what's happening.
How do you expect help when you don't accurately describe the symptoms?
RDavisinVA
Old July 23rd, 2016, 12:11 PM
SeriesIII
J
1973 Series III
Thanks Robert.
I just went out to troubleshoot to provide the forum with more details.
All troubleshooting was done at the side of my house. I didn't want to get too far and have to push it home.
1. As recently as yesterday it used to shift into gear (1st, 2nd, 3rd...) very easily. Now I need to let the clutch up and work the main gear lever into first gear.
2. The vehicle will move forward with the transfer gear lever (red) forward (high) and backwards (low).
3. The vehicle will not move backwards while in reverse with the transfer gear lever (red) in forward (high) or backwards (low). Feels like the rear brakes are preventing it from moving. The vehicle shifts into reverse but won't move even with the RPMs high.
4. Pulling the transfer gear lever (red) back and then forward does not appear to release the 4-wheel drive control lever (yellow). It stays down.
Old July 23rd, 2016, 07:35 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Much better, J.
If it's an 88 try the following and report back, please.
Put it in neutral main gearbox and T case.
Then can you push the vehicle backwards? yes or no.
Did you recently add new rear brake shoes?
If it's a 109, let us know...
RDavisinVA
Old July 24th, 2016, 09:29 AM
LRColorado
1990 Defender (200 TDI)
Could it be a seized transmission brake?
Old July 24th, 2016, 10:17 AM
SeriesIII
J
1973 Series III
It is an 88
Yes, it rolls backwards with it in neutral main gearbox and neutral T case
I haven't touched the brakes since purchasing the vehicle 3 yrs ago
I thought it could be the transmission brake (hand brake) so hit the drum a few times with a hammer and backed off the square adjustment bolt and no affect. The vehicle will roll backwards a foot to 3 feet then stops abruptly. Maybe I need to take off the prop and see what might be amiss with the transmission brake's pads, springs, etc. All the linkage looks okay when move the hand brake and observe it from below the truck and from through the driver's seat opening.
Old July 24th, 2016, 06:08 PM
Greg S
Greg Sutfin
1986 90
You pushed it home but now it only moves one to three feet before it stops abruptly. Three feet would be almost half a revolution of a tire which would be about two revolutions of the driveshaft and park brake. I doubt it is the park brake or driveshaft. Could be a broken Axel with something jamming after half a revolution.
The first description about it not getting any movement in any gear was poor but didn't rule out a broken drive shaft.
Old July 24th, 2016, 06:39 PM
SeriesIII
J
1973 Series III
Hi Greg,
It will drive forward. I only have the issue in reverse.
When driving the vehicle forward, I am driving forward 15 ft, not a great distance. When I put it in reverse it will roll back a foot or two, but then stop abruptly. If after attempting driving it in reverse once I try a second time, it won't move an inch backwards. It feels like I have a rock behind the tires and wont move in reverse at all.
Do you still think the axle could be the issue?
Old July 25th, 2016, 05:48 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Why not pull the axles and troubleshoot your truck for the obvious stuff. Good practice for trail fixes.
Old July 25th, 2016, 10:25 AM
RFD110's Avatar
RFD110
Rob Dennis
D90, D90, D110
Originally Posted by SeriesIII View Post
Hi Greg,
Sounds like the parking brake shoe may be loose and binding. Or possibly a brake shoe on the wheel. I have had this happen before with the parking brake.
You might try putting the transfer in neutral and then try using the gearbox in forward and reverse to see if it seems to work properly without the rest of the drivetrain disconnected.
Old July 25th, 2016, 11:10 AM
SeriesIII
J
1973 Series III
Is there a quick test to see if a half shaft is broken before pulling it out to look at it?
Old July 25th, 2016, 11:34 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Is this correct?
88 will shift into all gears.
Will drive forward.
When in reverse it will move backwards some of the time for a short distance and other times not at all.
RDavisinVA
Old July 25th, 2016, 11:48 AM
SeriesIII
J
1973 Series III
- 88 - Yes
- will shift into all gears. - Yes, but I have only driven it forward in first because I need to put it in neutral and push it pack to where I park it.
- Will drive forward. - Yes, but I have only driven it 15+ feet forward.
-When in reverse it will move backwards some of the time for a short distance and other times not at all. - No, it wont move backwards when it is in reverse. Feels like it has wheel chocks behind the wheels. I can get it to roll backwards one to 2 feet before it comes to a dead stop.
Old July 25th, 2016, 12:29 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Check the rear brake shoes.
There is the chance that the trailing shoe is hanging on the drum when moving backwards.
Recently had a similar issue with an 88 and adding a second return spring solved the issue.
RDavisinVA
Old July 25th, 2016, 12:32 PM
Contractor's Avatar
Contractor
Will
1969 IIA
There is the chance that the shoe is hanging on the drum when moving backwards.
x2
I was going to type the same thing.......I literally just had a very similar issue.
Old July 29th, 2016, 09:12 AM
SeriesIII
J
1973 Series III
Update:
I pulled off both rear tires and drums and didn't see any obvious issues with the pads, springs, etc.
I jacked up each of the rear wheels independent of one another, so the opposite rear wheel was on the ground. I put the vehicle's transfer case and main gear lever in neutral. Released the hand brake/transmission brake. The wheel spun in reverse randomly.
Here are two YouTube videos I took of the wheels seizing up.
I think the issue is with the transmission brake. Thoughts?
Sorry for the poor video quality and the wind in the mic.
v=sPzSWTOMsDA
Old July 29th, 2016, 09:30 AM
That is so strange.
As others have said, lets pull the driveshafts out and make sure they are still in one piece. If so, time to drain the rear diff. If no metal chunks from rear diff, I think you've cleared the rear end of blame (unless you want to open it up anyway for a look see).
So its time to drain the Transfer box and hunt for metal chunks.
Old July 29th, 2016, 10:38 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I still think it's the rear brakes.
Pulling drums and inspecting won'd do anything.
Read the post further up regarding the extra return spring before you rule out rear brakes.
RDavisinVA
Old July 29th, 2016, 10:46 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
You could pull the drive flanges off the rear wheels and rotate them, that way they are isolated from the rest of the drive train. If it still does it then the problem is as Robert has stated.
Old July 29th, 2016, 10:48 AM
Just leave the drums of to rule out the rear brakes.
If you think it is the parking brake, back off the adjuster.
series, series iii
94 NAS D90 Won't shift when running jperakis Defender Technical Discussions 3 July 3rd, 2015 02:07 AM
how tough is it to replace 1.22 LT230 gears with 1.4 gears cdb Defender Technical Discussions 13 January 5th, 2015 04:28 PM
Series III :: 1973 Land Rover Series III kraison Defender & Series Truck Registry 0 July 25th, 2014 02:07 AM
D90 Won't Shift, at all Linoge Say Hello! New Member Intros. 103 November 16th, 2013 01:17 PM
LT230 with 1.4 gears or just the 1.4 gears!! El Solis Wanted 3 May 13th, 2011 06:56 PM
