Series III - Won't shift in to any gears - Page 5 - Defender Source
Join the Defender Source Community Today
Old October 2nd, 2016, 11:48 AM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
After all that work!
Can you fill in more details? Like how would you trouble shoot this so it can be quickly found and avoid 2 1/2 months of down time?
Mike & Carrie
Originally Posted by SeriesIII View Post
Just wanted to share an update. Turns out my issue was a 59 cent lock washer on the rear main shaft. Took 10 minutes to replace the washer and I am back on the road.
Defenders draw attention. Don't buy one if you're shy!
Old October 2nd, 2016, 12:11 PM
Mike & Carrie
It is a well known and common problem with Series gearboxes.
Old October 2nd, 2016, 12:23 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Not to sound argumentative, but if this problem is well known, why wasn't it brought up 2.5 months ago?
Carrie wants to buy a Series so I'm just trying to educate myself.
Mike & Carrie
Old October 2nd, 2016, 12:29 PM
SeriesIII
J
1973 Series III
I am learning so much from other more experienced Land Rover owners. Each project I get more insight on my vehicle.
I try to share updates, pics and videos so others can search the internet and find solutions to their problems.
I got to give credit to the guys on "Guns and Rovers" for identifying this solution.
My issue came on with no warning signs (noise, vibrations, etc.) so if your vehicle abruptly stops driving in reverse I would remove the middle seat of your Series so you can access the inspection plate. Unscrew the four nuts on the inspection plate of the transfer case and see if the nut has backed off and is pressed against the bearing housing.
Attached is...
1. Pic of the broken lock washer on my vehicle
2. Pic of the nut backed off of the main shaft. If after removing the inspection plate you see this you know your issue. I got this pic from Mark on Guns and Rovers. Wanted to share it because it clearly shows the nut pressed against the bearing housing.
Name:	Lock washer.jpg
Name:	Nut in the transfer case.jpg
Mike & Carrie
Old October 2nd, 2016, 01:21 PM
Not to sound argumentative, but if this problem is well known, why wasn't it brought up 2.5 months ago? Carrie wants to buy a Series so I'm just trying to educate myself. Mike & Carrie
He was given advice that would allow the cause to be isolated to which main component. Once it was shown to be the gearbox, step one would be to look at the mainshaft nut.
Old October 2nd, 2016, 01:45 PM
HAWKER748
Nick Wilson
Rapier 127
Excellent news! Well done..
Old October 2nd, 2016, 02:16 PM
GuamPilot's Avatar
GuamPilot
Mike & Carrie Wendt
1986 90 2.5NA
Excellent summary! Exactly what I needed to know.
Mike &C arrie
Attached is...
Attachment 158881
Attachment 158882
------ Follow up post added October 3rd, 2016 04:22 AM ------
One more 'how it works' question.
If this sudden "can't reverse" situation happens, will you harm anything by driving it home using only forward gears?
Mike & Carrie
Old October 3rd, 2016, 09:55 AM
transientmechanic's Avatar
transientmechanic
1972 SIII
To reiterate,
Originally Posted by transientmechanic View Post
Too many cooks in the kitchen.
When 10 people on the internet tell you to go in 10 different directions for diagnosis, it's easy for it to become a wild goose chase.
Old October 7th, 2016, 05:31 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Hi John,
Thanks for the followup interest. No, I am still troubleshooting.
My rear brake shoes and drums were oil soaked and very worn, so I replaced the drums, shoes, two springs and the wheel cylinder on each of the rear wheels. Didn't fix the problem, but feel good that the vehicle now has new rear brakes.
I think my next step will be to pull the rear axles to see how they look. Any other recommendations?
Did you repair the oil leak or are those just sacrificial parts? I can't tell you how many owner repaired brakes I replace every year because the actual problem (hub seals, loose wheel bearings) was never repaired.
Matt Browne
series, series iii
94 NAS D90 Won't shift when running jperakis Defender Technical Discussions 3 July 3rd, 2015 03:07 AM
how tough is it to replace 1.22 LT230 gears with 1.4 gears cdb Defender Technical Discussions 13 January 5th, 2015 05:28 PM
Series III :: 1973 Land Rover Series III kraison Defender & Series Truck Registry 0 July 25th, 2014 03:07 AM
D90 Won't Shift, at all Linoge Say Hello! New Member Intros. 103 November 16th, 2013 02:17 PM
LT230 with 1.4 gears or just the 1.4 gears!! El Solis Wanted 3 May 13th, 2011 07:56 PM
