Series III gearbox trouble? - Defender Source
Old May 24th, 2015, 10:25 AM
SeaCowboy
Logan Mitchell
1975 Series III MOD Light Weight
Howdy!
I have been on an excellent roadtrip in my newly restored 1975 Light Weight, having run over 600 miles from Dallas, TX, to Roswell, NM.
The transmission and gearbox have been smooth and quiet the whole way.
This morning, however, as I was leaving the house in first gear, I heard a very loud THUNK.
Now there is no power to the rear wheels, and the hand break doesn't hold.
When I switch to 4 wheel drive, have power to front wheels and hand break works properly.
I would guess that many out there have had this happen, so any advice will give me a head start to fixing the problem.
Thanks!
Old May 24th, 2015, 10:26 AM
greenmountainrover's Avatar
greenmountainrover
Derek Chace
84 Lightweight FFR
Rear half shaft broken most likely
Green Mountain Rovers your Defender/Series sales and importation specialist.
802-655-4874
Old May 24th, 2015, 10:33 AM
SeaCowboy
Logan Mitchell
the shaft itself seems solid, and so do the U joints. will take another look, but suspect its something in the gearbox.
any other ideas?
Old May 24th, 2015, 10:40 AM
The half shafts are housed in the axle. You are referring to the drive shaft.
Old May 24th, 2015, 11:17 AM
Rear halfshaft broken
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old May 24th, 2015, 11:27 AM
Ignotus
gene
1960 109, w/200TDI
Rear half shaft, you have to take off the outer drive flange and pull out the inner axle. Do both sides, then take out the differential and get the broken bit out of it. Clean out the diff housing and put it back in then slide in the replacement axles. You do carry replacement axles don't you......
If you drive it in font wheel drive you risk damaging your rear diff with all the bits which may be floating around in there. If that is your only option remove both half shafts and the rear prop shaft to minimize the diff turning.
Gene
1960 109
1960 88 Ignotus
Blog;
Old May 24th, 2015, 12:39 PM
The short side usually goes first. Pull that one and see. If you are lucky you can pull the broken part out with a magnet on a stick, and if it's a clean break just stick in another.
Originally Posted by pendy
I'm here for the D's
Old May 24th, 2015, 01:55 PM
SeaCowboy
Logan Mitchell
Thank you Gents,
Now I know what to look for online....any suggestions?
Since this is a 1975 Light Weight and more narrow than normal Series III, would the axles have to be specific to Light Weights?
Old May 24th, 2015, 02:28 PM
rwollschlager's Avatar
rwollschlager
Rob Wollschlager
72 SIII 88
the shafts are the same as normal series II-III shafts, the lightweights do have different drive flanges, but that won't be an issue here.
Old May 24th, 2015, 02:42 PM
Don't start buying stuff until you know what's wrong though!
Old May 26th, 2015, 04:56 PM
SeaCowboy
Logan Mitchell
According to the Gents at John Craddock's, the half shafts are specific to the Air Portable. But thankfully, still reasonably priced and in stock! I am pressed for time so have ordered the parts before taking the axle apart, so will hope for the best.
Will let y'all know how it turns out.
thanks again
Old May 26th, 2015, 11:12 PM
rwollschlager
Rob Wollschlager
72 SIII 88
if you convert to normal series II-III drive flanges, then you can run normal series II-III shafts.
series, series iii
Ratty's Series III :: 1977 Land Rover Series III Robthompson4 Defender & Series Truck Registry 0 January 11th, 2015 06:18 PM
Series III :: 1973 Land Rover Series III kraison Defender & Series Truck Registry 0 July 25th, 2014 03:07 AM
LT 95 gearbox..do I have to remove gearbox from truck to replace reverse idler shaft? Ncmike Series Technical Discussions 3 April 13th, 2014 03:33 PM
Series II (suffix A) Gearbox jaygoss For Sale - Parts 1 August 26th, 2010 04:37 PM
Maya Culpa series 3 Question about main shaft slop in gearbox airbornrover Series Technical Discussions 2 May 21st, 2009 08:09 PM
