Series III - Front end veers - Defender Source
Old July 4th, 2011, 01:05 PM
hye1978
Paul
1962 Series 2a
Hi All,
Hoping someone can help me out here. I have a series iii that I am getting ready to drive daily, but it has this problem that the front end veers to the right.
Cheers,
Paul
Old July 6th, 2011, 08:36 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Should be standard alignment stuff, or a dragging brake shoe.
Old July 6th, 2011, 02:33 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Does it veer under braking or just when driving along?
If under braking check for brake shoe contamination.
Mike Hammond
Old July 7th, 2011, 12:31 AM
hye1978
Paul
1962 Series 2a
I thought the same, but it's not under brakes. just humming along at 35 - 50 mph.
------ Follow up post added July 6th, 2011 09:32 PM ------
Hi Mike,
Thought the same as the other chap. It's basically at normal driving speeds, off brake.
Old July 7th, 2011, 02:19 AM
mikeslandrover
Mike Hammond
Check the steering relay in the chassis, make sure it doesn't have a tight spot, same with the steering link joints.
What about the spring bushes are they good all round, front and back axles?
Check the preload on the swivels too, and the wheel bearings. a thorough check for wear of all the running gear is needed.
Finally and easiest check the brake isn't rubbing and causing the drag, are both hubs the same temperature after you have driven it?
Mike Hammond
Old August 22nd, 2011, 01:33 AM
mikeslandrover
Mike Hammond
What did you find. Is the problem sorted?
Mike Hammond
series, series iii
Series III Instrument Cowl in Aluminium SafariHP The Vendors Loft 4 August 13th, 2010 09:06 AM
1974 Registered Series III Hybrid-RHD wlykes For Sale - Vehicles 5 July 23rd, 2009 12:45 AM
Series III Cam Timing ... bossongs Series Technical Discussions 0 April 30th, 2006 05:11 PM
Series III Bikini top? Any Defender crossovers? KevinNY Series Technical Discussions 2 November 14th, 2005 04:34 PM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
