Series III brake upgrades - Defender Source
Old February 25th, 2011, 02:15 PM
76ROVER
Jason
76 SERIES
Hi,
I am looking to upgrade the braking on my series III. I have the power brake pedal box for series III, but have not decided what servo and and master cylinder to use yet. I plan on using some coil axels with disc brakes at each corner so I want to make sure I can move enough fluid. So can I use a defender unit? or should I stick with a series set up?
Thanks for the input
Old February 25th, 2011, 02:46 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
You can use the late2a and s3 power brake set up. I've seen several of these with disc brake upgrades on series axles. Some people also have run hydroboost set ups too. This is what I'm doing on my rig. I used a s3 pedal tower, a hydroboost unit from an escalade and a late 80 blazer master cylinder. This route requires a small amount of fabrication and power steering pump too, but its a great reason to ad power steering at the same time.
Daniel
Old February 25th, 2011, 11:15 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
On my series I run the stock s3 power setup with the aftermarket replacement master cylinder from rovers down south. It pushes the toyota disc brakes I run just fine.
Old March 3rd, 2011, 08:48 PM
76ROVER
Jason
76 SERIES
Thanks for the input guys, I will probably just go with the stock series III power set up for now. Enjoying the build thread Dan.
brake, series, series iii
1974 Registered Series III Hybrid-RHD wlykes For Sale - Vehicles 5 July 23rd, 2009 12:45 AM
1974 III Series 88 SW Prototype For Sale Nil For Sale - Vehicles 0 August 10th, 2005 02:39 PM
$100,000 LR Series III 1964 paulb Misc. Chit-Chat 5 September 15th, 2004 01:09 PM
Discovery Series III Spy Pics boshea Misc. Chit-Chat 2 December 31st, 2003 03:16 PM
