Series IIA turn signsl switch source - Defender Source
Old July 15th, 2012, 12:52 AM
'm helping my buddy do a full rewire of his Series IIA, and the turn signal switch is shot. Could use a lead on one avail. He tried getting ahold of awise Owl but no response.
Also trying to figure out where the brake switch for stop kamps is. Looked all over pedal box and didn't see anything. This is a single valve master cylinder.
Mark Kellgren
KM4BOR
Old July 15th, 2012, 08:17 AM
Try Ike for the turn signal switch. Pangolin 4x4. It's gonna cost, painfully I'm afraid.
Brake light switch is on a 4 way junction on the right frame rail (left hand drive, that is)
Old July 15th, 2012, 08:46 AM
^THIS. My lever in the series was on its last leg for years and I kept JB Welding it. Finally let go and ordered one from Ike in January. $27 shipped, which I think was like $19 + $8 shipping...not as bad as you'd think! Also, if your turn signal wheel is in bad shape get one from him too...it's like $4. Thanks to both these parts my turn signal self cancels in the Series which is nice!
The brake light switch is a plunger style, located right on top of the brake booster (at least in my '71 IIA). Save yourself some trouble...ONLY get a replacement from RN. I hate to say it, but I went through 6 switches from other "usual suspects" before going to RN. Theirs is more similar to the original style, and in this case makes a difference. Ironically had this exact conversation with bcourtney this past week when I bumped into him and he was literally having the exact same issue (on his 4th or 5th, likewise told him to get it from RN and be done with it).
Old July 15th, 2012, 09:10 AM
you guys.are awesome
Mark Kellgren
KM4BOR
Old July 15th, 2012, 09:58 AM
texrover's Avatar
texrover
Jason
Nathan,
Is the RN switch the brass body type?
Thx
2003 RR L322
1971 Series IIA
1983 110 SW (Incoming)
1994 D90 ST (PO)
Old July 15th, 2012, 10:08 AM
Originally Posted by texrover View Post
Nathan,
Thx
That is correct. If you can wait until I get home later today I can probably: a) take a pic of it, b) pull up the invoice with the exact part number.
Old July 15th, 2012, 06:17 PM
The one I used was RNC478.
Old July 15th, 2012, 06:39 PM
The 5 way connector is where the brake light switch is. Careful as the connector is spendy and hard to find (when I needed one I found it as Moss which is for british cars).
Ron
Old July 17th, 2012, 07:02 PM
Albersj51
jason
1967 2a
Are you using a factory harness or painless/EZ wiring? I ask because I am almost done rewiring mine with an EZ wiring harness, so if you have some questions I am more than happy to help.
Depending on the truck, as has been stated, the brake switch is either mechanical (brake pedal tower) or hydraulic (brake junction on the left side). I converted mine from single circuit to dual circuit power and decided to retain the hydraulic switch based on all of the negative feedback regarding the mechanical switches.
Turn signal X3 - Ike is the guy to talk to. I believe he has some NOS Tex-Magna Lite switches available. I also rehabbed my switch with one of his cancelling wheels...well worth the $10 for the new rubber.
Jason
series, switch
97 Turn Switch aaronlam Defender Technical Discussions 7 January 11th, 2012 09:40 PM
Need Turn Signal Switch 48vphantom Wanted 1 September 24th, 2004 02:18 PM
Series IIa short wheel base TDI Guy Wanted 3 August 12th, 2004 01:15 PM
Great looking Series IIA on EBay boshea Misc. Chit-Chat 3 April 24th, 2004 12:14 PM
