Series II or Series III door hinges which ones to run - Defender Source
Old December 14th, 2011, 01:58 AM
aka rover's Avatar
aka rover
ed angel
95 D90
Im putting togather a 67 Series 109 and am not going original on the build and was wondering if there was a reason i should switch to the later style hinges. I am running early Defender doors with roll up windows a 5cyl. Mercedes Turbo diesel etc. so not OG. Is there any reason other than looks to change to the later hinges ? . I am getting ready to buy hinge pin kits and mounting hardware and was thinking i would or could just buy the later hinges.
85 D110 3.5 3 DR
Old December 14th, 2011, 06:21 AM
III hinges:
Can use defender mirrors
Not rebuildable
Cause damage to door pillar if door opens too far
Modern 1970's appearance
IIa hinges:
More difficult to fit defender mirrors
But easier to fit early mirrors. SIII style mirrors give good functionality
Rebuildable
Do not damage door pillar
Quaint 1950's agrarian appearance.
Rebel
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old December 14th, 2011, 06:32 AM
And, with take apart hinges, you can easily remove the doors.
Old December 14th, 2011, 09:06 AM
TeriAnn's Avatar
TeriAnn
Teriann Wakeman
1960 Dormobile
SIII hinges have less slop and hinge pins do not have to be periodically tightened. Nor have bronze bushings that need replacing. They give the door a more solid feel when you close them. I switched over about a year ago and am happy that I did.
TeriAnn
Old December 14th, 2011, 03:02 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
In the summer I don't even bother fitting the spring, lock washer and nut on the SIIA style. It lets me remove or refit the doors in just a couple of minutes depending on the weather.
If you never, or rarely, remove your doors and keep the stop rod fitted, then the SIII type might be preferred.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old December 14th, 2011, 04:34 PM
aka rover's Avatar
aka rover
ed angel
95 D90
The S2 hinges allow the door to open 180. Usually its not an issue, but if you use it for camping etc it is nice to be able to open the door all the way. From an aesthetic standpoint I like the industrial shaped-with-a-purpose look of the S2 hinges.
-Jeff
Thanks to everyone who awnsered, JSBriggs the 180 deg. to open door is something i over looked, I am setting this up as a camper and will need the rear doors to open over 90 degs. So looks like Ill be keeping the IIa hinges and rebuilding them.
When ordering the IIa rebuild kits is there any better than others rebuild kits? Some are proline some are allmakes etc.
Thanks Ed
85 D110 3.5 3 DR
Old December 14th, 2011, 05:58 PM
TeriAnn's Avatar
TeriAnn
Teriann Wakeman
1960 Dormobile
Proline is The Rovers North generic house brand. Anything they buy that is not genuine Land Rover gets labeled as proline regardless of where RM purchases it from. Rovers North does buy from Allmakes. So it is possible that you are comparing Allmakes with Allmakes sold by Rovers North.
TeriAnn
Old December 14th, 2011, 06:05 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Thanks TeriAnn
I wont be to concerned on which to buy if im not buying genuine
Hey TeriAnn
Im converting my 109 to a expo type camper and have spent alot of time on your page and its links. Im looking for a site or thread that has pics of what some have done to convert there 5 doors to a camper. Any help would be great.
85 D110 3.5 3 DR
Old December 15th, 2011, 09:51 AM
TeriAnn's Avatar
TeriAnn
Teriann Wakeman
1960 Dormobile
Hey TeriAnn
Not a whole lot of help there as my primary focus has been on 109 regular & dormobiles. The best non Dormobile or Carawagon 109 station wagon expedition conversion was done by Herbert Zipkin. I have a web page covering his truck.
http://www.expeditionlandrover.info/G_HerbZipkin.htm
You might find some ideas in my Dormobile & Carawagon pages.
Most long distance travel set ups I have seen in 109 station wagons where people camped primarily inside included putting furniture across one or both rear doors.
It is important to first identify your needs. Like how many people would be camping. Do you do mostly base camp traveling or camp in a different location most nights? For base camp situations you are best off setting up camp outside. You might consider a side awning with detachable walls as a tent alternative. There is really no place for beds in a 109 station wagon that does not have a lifting top unless you remove the rear row of seats.
A nice set up would be a side awning with swing out arms as is common in South Africa. A chuck box that can hand on the side of the truck from the rain gutter, cots & a fold up table. A 109 size side awning provides a LOT more space than the inside of the truck and if your gear does not live inside the truck the truck remains versital of other uses. Just a thought. Even a 109 regular is very crowded for more than one person camping in back.
TeriAnn
Old December 15th, 2011, 02:56 PM
aka rover's Avatar
aka rover
ed angel
95 D90
Thanks TeriAnn
Ill check it out.
85 D110 3.5 3 DR
Old December 19th, 2011, 04:17 PM
SII hinges and pack the bronze/brass ball with anti sieze.
door, series, series iii
Rare NOS Series II and III Parts on the way SafariHP The Vendors Loft 0 January 18th, 2011 07:22 PM
1974 III Series 88 SW Prototype For Sale Nil For Sale - Vehicles 0 August 10th, 2005 02:39 PM
Stage 1, series III pickup wanted m.olivares Wanted 0 February 14th, 2005 01:50 PM
$100,000 LR Series III 1964 paulb Misc. Chit-Chat 5 September 15th, 2004 01:09 PM
