Series Heater Blower - Defender Source
Old November 19th, 2015, 10:25 AM
JohnBullsBollocks's Avatar
JohnBullsBollocks
Don
1963 IIA 109
Hi all, has anyone attempted to use a Defender heater blower motor on a Series vehicle? As you know, the blower assembly is NLA and replacement motors are crazy money from the usual suppliers. Used motors will likely suffer the same fate as the 40 or 50 year old original.
ID:	135163   Click image for larger version
Old November 19th, 2015, 10:51 AM
61rover's Avatar
61rover
John Crouse
This looks like a Kodiak Mark IV. Is that correct?
Old November 19th, 2015, 10:57 AM
Can't get it rebuilt at a local electric motor shop?
http://www.expeditionlandrover.info/Kodiak_heater.htm
Old November 19th, 2015, 10:59 AM
The Dro
Dro
1988 Ninety
Negative...
Old November 19th, 2015, 11:01 AM
JohnBullsBollocks
Don
1963 IIA 109
Actually, this is the style used on late IIA NADA and SIII models. I used a SIII blower assembly on my 1969, and it fit perfectly. The Kodiak was a GREAT heater and I had one in my 1964 Safari. But you are right, they look similar. I am working on another 1969 that I acquired in September. The motor is fried.
Old November 19th, 2015, 11:16 AM
JohnBullsBollocks
Don
1963 IIA 109
This is what the Defender version looks like. The motor just unbolts from the flange. The dimensions of the fan appear to be the same. Although not cheap, this one is about half the price our friends at the usual suppliers charge. Might be worth the try.
Old November 19th, 2015, 11:54 AM
Originally Posted by JohnBullsBollocks View Post
The dimensions of the fan appear to be the same. Although not cheap, .....
http://www.defendersource.com/forum/...0-a-38561.html
http://www.defendersource.com/forum/...tml#post250231
VDO/A/C Heater Blower Motor PM136 - Read 1 Reviews on VDO #PM136
$25.
Old November 19th, 2015, 12:45 PM
Contractor's Avatar
Contractor
Will
1969 IIA
I think this is a replacement for your blower motor.
http://www.napaonline.com/Catalog/Re...Dp%3d3%26N%3d0
Old November 19th, 2015, 02:58 PM
Somewhere in my notes on the Kodiak Mk III (yes I put one in my build) is that the motor is similar or same as 50s Ford/Chevy. While Terriann's notes point to a Napa unit, (and links are given) if you can match the mounting stud spacing, motor size, rotation and shaft length then you are in pretty good shape.
heater, series
Series III heater blower assembly needed bstraw Wanted 1 July 30th, 2012 08:42 AM
Left hand drive heater blower motor for series 3 Macker Wanted 0 October 17th, 2010 01:59 PM
1983 RHD Heater Blower Switch Part Number newfD90 Defender Technical Discussions 5 November 20th, 2008 02:38 PM
Need help with heater blower motor! Firefighter2904 Defender Technical Discussions 27 October 15th, 2007 09:51 AM
NAS 110 Heater/AC Combo Blower COSteve Wanted 2 July 27th, 2005 02:50 PM
