series front hub seal - Defender Source
Old November 12th, 2008, 12:46 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Question series front hub seal
would like to know any tricks to sitting the seal in place which happens to be a National brand. other then the freezing it to shrink a little, using the old race as a sort of drift(hope i used the term correctly). both of which i already used. had to step away as i nearly went 2001 space odessey ape on it with the hammer. wondering if i could use some emery on the paint like coating around the outer edge so it would slide in better or something??
And yes its always these little things that i get hanged up on.
so like before if there are any little tricks learned that you are willing to share i would greatly appricate that.
Old November 12th, 2008, 08:48 AM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
Nothing fancy here. A light smear of Permatex # 2 around the edge of the seal, then a gentle tap-tap-tap with a tiny hammer to ease the seal into the hub, working around the circumference and using fingers to prevent the opposite side of the seal from popping out, until the seal is almost seated. Then I use a scrap of wood large enough to cover the seal and tap it with the hammer to seat the seal flush with the hub.
John Karlsson
Hope Valley, RI
series
Inner hub seal seating depth KevinNY Defender Technical Discussions 32 September 12th, 2009 02:05 AM
Which direction to install rear outer hub seal? cgalpin Defender Technical Discussions 16 September 23rd, 2005 12:06 AM
Front Vent Seal Replacement Campbell Defender Technical Discussions 16 October 28th, 2004 09:11 PM
