Series door top rebuild - Defender Source
Old January 22nd, 2013, 07:30 PM
I'm most likely just going to get those fancy aluminum door tops from Rocky Mountain, but I stripped my door tops down to get the frames galvanized and have two issues
1. I didn't realize the studs were welded in. Mine are not in the best of shape but I am not sure I feel like cutting/drilling them out and welding in new ones. Seems beyond my threshold of pain
2. I need to replace/repair some of the aluminum cladding - the angled vertical strips on both sides and the bottom section of one due to holes being made by the PO. I don't see these for sale anywhere and I am not sure how easy cheap donor door tops with decent aluminum cladding can be had.
Thoughts? I kind of want to keep the original door tops, albeit galvied with fresh studs and channels, but I want a nice end product that will last another 50 years, so I know what the safe bet is. Maybe I'll galvy the frame anyway and see how the studs turn out.
http://www.parabolicsprings.com/products.html
Originally Posted by pendy
I'm here for the D's
Old January 22nd, 2013, 07:41 PM
Yup. Thoughts on the studs? I had assumed they were like the defender and I was going to put in a stainless set I have been hoarding.
Old January 22nd, 2013, 07:51 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Man I would just fork out the money for the RM doortops. They are very nice and less painful. Plus you'll need the rear window tracks anyway
MUDSUX
Old January 22nd, 2013, 07:53 PM
I dunno. I think the repro door tops are OK, and not too expensive. Otherwise just run a die over the threads to chase them of crud.
Old January 22nd, 2013, 07:55 PM
I guess I'll see how they come back from galvy and go from there. But Forrest is thinking what I'm thinking
The sad thing is I have a spare set of NAS door tops here too... Just want to keep the series look.
Old January 25th, 2013, 10:36 AM
I gave up on the series look when I found a set of MOD 110 doortops for cheap.
Old January 28th, 2013, 11:50 PM
aka rover's Avatar
aka rover
ed angel
95 D90
I ended up going with a set of early D110 doors with roll up windows. I like the look of the series doors but got tired of the window only sliding one way.
85 D110 3.5 3 DR
Old January 28th, 2013, 11:54 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
I have the RM door tops on mine, i really like them, not sure who painted them though as they came on the truck, but it was not a great paint job (very thin), it adds to the character i guess.
------ Follow up post added January 28th, 2013 11:57 PM ------
Attachment 65424
How did you do the trim piece that makes it look like a series door? I have a set of early 90 pushbutton doors and i want to put a galvy trim piece on it but dont know how to achieve it.
Old January 29th, 2013, 12:16 AM
aka rover's Avatar
aka rover
ed angel
95 D90
These doors are the early 110 doors I believe 1983, they came with galvey trim from the factory as far as I have found. Been hard finding info about these doors but they blend in on the series pretty well.
85 D110 3.5 3 DR
Old January 29th, 2013, 12:22 AM
JohnsD90's Avatar
JohnsD90
Hmm, atleast i know there is a real part to look for then!
Old January 29th, 2013, 07:30 AM
Yeah the early defender doors do look convincing (and the galvy strip is faux but real galvy/steel), but I'm all about the half doors. Only a few days away from finding out what my old frames will look like after galvy and I'll go from there.
Old January 29th, 2013, 11:15 AM
TeriAnn's Avatar
TeriAnn
Teriann Wakeman
1960 Dormobile
One piece doors are not just s Defender thing. There were some Canadian spec Series II Land Rovers that came from the factory with one piece doors. So to a limited extent it is also a Series thing.
Some door top related observations:
Aftermarket Series door top reproductions often do not have the correct inward slant. So the door tops stick out from the hard top and top of the windscreen. Makes for drafty wet driving. Also they seem to rust easier.
The Rocky Mountain door tops are great but have a method of locking which keeps them from opening as far as D90 door tops do. Some people find it hard to rest their elbow on the open door frame.
D90 door tops are expensive but the fit is very good in Series truck. And you get to rest your elbow on the door frame.
The rubber seal between the door top and bottom is good for keeping water from entering the inside of the door along the seam BUT ...where the seal goes past the mounting studs there is a slot that opens to the outside to allow drainage. The only problem is that the water goes down the studs into the the lower door instead. Result is rusted mounting studs & fixings, rust holes along the bottom of the doors and water damage on interior door panels. A ring of RTV around the mounting studs where they go into the lower door makes all the difference in the world.
TeriAnn
Old January 29th, 2013, 11:27 AM
The Dro
Dro
1988 Ninety
If you go the RM route... I'll tag along and buy a set with you.
Old January 29th, 2013, 12:24 PM
I happen to have a spare set of NAS D90 door tops so I always have that as a fallback. But what's this elbow difference you speak of? I find with the D90 door tops in that the channel isn't very comfortable to rest my elbow on, and in fact my elbow swelled up to the size of a baseball after a long trip doing so. Are you saying the RM ones don't open up as much on the back side?
Old January 29th, 2013, 01:59 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
... Are you saying the RM ones don't open up as much on the back side?
Correct, because of the window locks and the way the glass is cut, they don't open as wide.
MUDSUX
Old January 29th, 2013, 02:23 PM
Good to know, thanks.
Old January 29th, 2013, 02:39 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Question
While waiting for RN to manufacture lower doors as well
I have 3 sets of Series doors waiting to be refurbished.
I haven't found yet the "how to skin a Series door" for dummies.
Anybody with a proven, simple method or a good link with good photos explaining what to do and how?
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old January 29th, 2013, 03:08 PM
Bottoms or tops?
I will post some pictures when I get a chance and I haven't put the skins back on yet, but it really isn't very hard. I bought a tool that helps get started peeling the skin back but you could do it without the tool. You tape up the edges to avoid scratches, and carefully pry up the skin. If you do it in stages it goes quite well and you just have to bend it up enough to pull the skin off.
Oh you have to drill out a few rivets first, but it's obvious which.
The tops are a little harder because of the glass channels, but otherwise much the same.
Old January 29th, 2013, 03:23 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Bottom bottom well they're in good conditions given their age, but having 3 sets I'd like to try and totally rebuild/improve one to make it last forever well almost!
For the 109", I'd like to do the job once, and do it the best I can...like, having the inner chassis galvanized?
I guess I know what the special tool is, there was a set on the market, a small hammer, a dolly and and some sort of chisel to skin the door with...I think they're just common tools, the dolly would be useful tho.
Isn't the aluminum skin likely to crack when you bend it in and out of shape?
Michele
D90 VNTdi
[O]===[O]
Old January 29th, 2013, 04:23 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Oh.
Annealing.
That black art which involves full moon, a bonfire and a dozen virgins before being mastered properly?
And a flame thrower?
Uhm...
Michele
D90 VNTdi
[O]===[O]
door, rebuild, series, top
1966 Series IIA Rebuild punter Truck Build-up's & Restores 67 May 14th, 2012 04:33 PM
Series Parts Scored from Lybia SafariHP The Vendors Loft 0 March 5th, 2011 07:54 AM
Adapter plate for series 1962siia88 Series Technical Discussions 7 September 8th, 2010 01:16 AM
Conatiner Arrival means Defender / Series Parts Clean Out SafariHP The Vendors Loft 18 December 5th, 2008 09:38 AM
