Series door top rebuild - Page 2 - Defender Source
Old January 29th, 2013, 06:08 PM
Not really a dark art. You can use a bar of soap. Rub it on the surface you are annealing. When it darkens you know that it has gotten hot enough. Allow to cool and work the metal.
I assume that you can get a MAPP torch in Italy...
I didn't bother annealing. I just used a Stanley flat pry bar and worked my way around (took three passes) until I had the frame loose. To put the skin back on, I used a wood block and a rubber mallet to bend the edges back. I did resort to using a body hammer here and there.
The only tricky part is the area where the "shoulder' is.
@charles;
If you have the skins off the door tops, and they aren't too rusty, then a run thru the galvy will do them wonders. Only thing is the threads on the studs. You'll want those to be decent. The channel where the glass channel goes can be swiss cheese, as long as you can get a screw into it here and there. Once the door top is reassembled and you have the trim pieces on you'll never know.
One thing you'll want for doing body work is a set of boards for your sawhorses that you cover with carpet.
Old January 29th, 2013, 08:03 PM
True, you will get some cracking unless you're extremely careful (ask me how I know!)
Old January 30th, 2013, 12:37 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Nice...
Thanks.
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old February 1st, 2013, 01:53 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Originally Posted by Cube II View Post
Oh.
Annealing.
That black art which involves full moon, a bonfire and a dozen virgins before being mastered properly?
And a flame thrower?
Uhm...
You can do it with MAPP or propane instead of a flame thrower but the chicks are non-negotiable!
JL
Old February 1st, 2013, 02:00 PM
I will trade you limestone early 90/110 door tops for NAS doortops if you realy want the series look, or you could just paint the NAS ones series colors. Only a nutter would be able to tell the difference.
The NAS/early 90/110 tops are WAY better than series doortops IMHO.
Old February 1st, 2013, 02:56 PM
Cube II's Avatar
Cube II
Michele
1997 D90
I'll work on that part
Great to hear from you!
Where have you been?
Don't tell me...snowmobiling?
Michele
D90 VNTdi
[O]===[O]
Old February 4th, 2013, 10:41 PM
I made a new thread in the small projects section. I'll update it when I put the skins back on.
http://www.defendersource.com/forum/...593#post411593
While waiting for RN to manufacture lower doors as well
I have 3 sets of Series doors waiting to be refurbished.
I haven't found yet the "how to skin a Series door" for dummies.
Anybody with a proven, simple method or a good link with good photos explaining what to do and how?
Originally Posted by pendy
I'm here for the D's
Old March 1st, 2013, 02:40 PM
71exmod
Bob
69 SIIA Bugeye
X2 on the early defender door tops. I have had both RN's and early defender ones. If I had to choose I'd take the defender ones. The RM's are good also and more reasonably priced. The defender ones can be pricey.
Old March 4th, 2013, 04:21 PM
71exmod
Bob
69 SIIA Bugeye
door top skins
Door tops are skinned and will be coming your way tomorrow. They are all straight the lens has distorted the outer ones
Old March 4th, 2013, 04:39 PM
Whoohoo! Thanks Bob!
Old March 28th, 2013, 12:13 PM
71exmod
Bob
69 SIIA Bugeye
how did you make out putting the skins on?
Old March 28th, 2013, 12:35 PM
I have not installed them and I suspect it will be a while before I do so because I want to paint the skins first. Although thinking about it, I guess I should paint the frames too (which are now galvanized).
I'll give it some thought, but maybe I should prep/prime the frames and skins, install the skins, then they just need the final paint, which will be later in the project.
door, rebuild, series, top
1966 Series IIA Rebuild punter Truck Build-up's & Restores 67 May 14th, 2012 04:33 PM
Series Parts Scored from Lybia SafariHP The Vendors Loft 0 March 5th, 2011 07:54 AM
Adapter plate for series 1962siia88 Series Technical Discussions 7 September 8th, 2010 01:16 AM
Conatiner Arrival means Defender / Series Parts Clean Out SafariHP The Vendors Loft 18 December 5th, 2008 09:38 AM
