series build update - Page 4 - Defender Source
Old February 13th, 2011, 05:35 PM
phoenix37's Avatar
phoenix37
john
You better stop listening to Timm or your going to end up with a truck that can do stuff like this
Old February 13th, 2011, 05:44 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
Nice shot! Haven't seen that one before. You can tell from this picture how far back his shock is too. I dont have that same hoodlum driver thing going on that Timm has cultivated! Thanks.
Daniel
Old February 13th, 2011, 09:00 PM
Originally Posted by 1962siia88 View Post
I'm not sure about that. As per usual I'm just following direction from Timm. Hopefully I'll get to drive it someday and I'll let you know! The bottom of the shock is about 4" behind the axle. The stock series has the shock about 3" behind the axle.
Daniel
Yeah, but it's not booger welded to the axle housing. Also curious why no parabolics and military shackles....afraid to go all the way?
Old February 13th, 2011, 09:02 PM
Yeah I don't claim to know anything about suspensions, I just know basic physics tells me that will produce a rotational force (torque) and given both sides will be on the rear of the axle wrap. Maybe your springs are super stiff, but it just doesn't sit well with me. I assume leaf spring trucks have the shocks on opposite side to counteract each other (although really guessing).
Any reason not to angle the shock slightly and half the length of the arm for example? Again, don't know what I am talking about so the answer might be obvious, but just curious.
Originally Posted by pendy
I'm here for the D's
Old February 13th, 2011, 09:04 PM
Sorry should have read your reply closer. Only one inch more doesn't sound bad, but sure looks like a lot. I"ll have to go look at my series in the morning as I never noticed it being too far out.
Old February 13th, 2011, 09:47 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
Bill you have some classic quotes on here. I am actually afraid to go all the way. You found me out.
I may end up using longer shackles at some point but from others' experience the stock springs give a firmer ride than the parabolics and obviously from the pic above articulation isn't a problem with stock springs. I had parabolics on this truck before this project and considered using them but Timm convinced me otherwise. Plus I was able to sell them to help fund this thing. How is your project coming along?
Daniel
Old February 14th, 2011, 12:25 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
Charles if you look at the picture of my shock set up closely you can see the stock series ubolt/spring plate with the shock mount. Its hiding right behind my shock and is partially visible in the picture. Of course its on upside down but that doesnt change the distance from the back of the axle to the lower shock mount.
The other thing is that if it doesnt work properly I'll change it. Fear of getting things wrong has seriously slowed this project down, plus I dont want to bug Timm for free advice every other day. I'm really hoping to be driving this thing by late April for the mendo trip (annual rover camping trip with many series trucks) but that seems less likely as time goes forward. Hopefully by summer I'll be done.
Daniel
Old February 14th, 2011, 12:36 PM
Well, don't wanna second guess your thinking, BUT...
If you left the old spring perch where it was and welded a second spring perch on top, ya coulda used the old shock mount plate on the bottom and fabbed a new plate on top. Use (grade 8) bolts instead of ubolts. Spring and axle samwich, with chips and a pickle.
Don't bug Timm, use the Force!
PS that front diff looks awfully cranked. Hope you have some caster corrected swivel balls to go on there.
Old February 14th, 2011, 01:46 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
The problem with doing the shocks like that is the power steering is in the way on the drivers side. This is why the ford mount is used to bump the shock outward and clear the power steering linkage. I could have done it that way with a shorter shock that would limited my travel.
As far as the caster goes, Timm actually came over and did all this part for me so I'm sure its going to be acceptable. I dont remember the actual degrees anymore and didn't take any notes but it wasn't eyeballed and was not clocked too much at all iirc.
Thamks.
Daniel
Old February 14th, 2011, 02:19 PM
it may look funny but I don't see how having the shock that for off the axle is really going to cause spring wrap. I highly doubt the shock valving is stiff enough to affect a spring pack that thick. The pinion angle looks about stock for a coiler axle.
Old February 14th, 2011, 02:26 PM
oilburner's Avatar
oilburner
JL
large pile of parts
One of the biggest issues with a spring over is trying to control axle wrap. By stepping out the shocks like that, you have a great reduction in axle wrap and the overall effect on handling is pretty low as the shocks on a leaf sprung rig are not as important as a coiler, lots of interleaf friction to help with damping. I find it looks cleaner than having a great big antiwrap bar.
The front axle looks to be built right, no need for goofy swivel balls.
You're on the right track!!
If you talk to Timm tell him JL from way up north says hi, have not talked to the wildman in a few years
JL
Old February 15th, 2011, 08:48 AM
Yeah let me re-iterate I don't claim to know anything about this stuff. Certainly don't let my (or anyone else's) comments derail you. Maybe one day one of our comments will be useful in some way, but if not, consider us entertainment.
Old February 15th, 2011, 10:16 AM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
I love the comments. Keep'em coming! I'm my own worst enemy on this project between my lack of knowledge and skill. Work is the other nagging issue. Ive got two small companies and I really need to get my year end stuff off to my acct! It's hard to reconcile bank statements when all you can think of is rover related.
Hoping today to get the front axle on my bench to weld up the other side and start finalizing my
steering arms. While it's out i will paint it, run the brake lines and install the front diff.
For those who have asked about Timm I did actually speak with him yesterday and passed along your messages and hellos.
Daniel
Old February 16th, 2011, 06:06 AM
Cube II's Avatar
Cube II
Michele
1997 D90
HA! I was there that day. I have a couple of those pics. I should go dig them out. ..
-Jeff
Please do!!!!
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old February 17th, 2011, 06:10 PM
oilburner's Avatar
oilburner
JL
large pile of parts
For those that are concerned about the height, those springs will settle super quick. As soon as you start bending a rover spring backwards on itself like you can with a spring over, it loses a lot of height. You you cna get a spring over down to almost the same height as a 109 1 tonne. Most of the time people run larger tires which raises the vehicle too. Dan make sure you think about the way the axle will be positioned when the springs sag with your shock positioning - Looks like you are getting it on. I am sitting on a Gen IV 6.2 from an Escalade, trying to figure out whether I want to go diesel or gas on the next truck. All these GM swaps are making it difficult to decide.
JL
Old February 17th, 2011, 06:14 PM
Cube II's Avatar
Cube II
Michele
1997 D90
You pick engines like apples!
[OT]
I might make it to Canada this summer, after the National Rally, let's keep in touch!
[/OT]
Michele
D90 VNTdi
[O]===[O]
Old February 18th, 2011, 10:41 AM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
Thanks for the advice. Hopefully I'm in the right spot. The next move is to begin installing the engine trans and tcase so I'll get some weight over those springs and make changes if necessary. That 6.2 is an aluminum block isn't it? I'm considering that for my next project too. It's either that or an lq9 which I believe your motor replaced. I keep finding little bits for the next project but I have to remind myself that it's one at a time or I'll never finish.
So the front axle is on the bench. Hopefully I'll get it cleaned up and weld the other shock mount to it this weekend. While it's out I will also clean up the chassis in the engine compartment and get my frame side engine mounts welded on. They are done and ready to go and their location is all figured out too. Hopefully it won't rain too much this weeked.
Daniel
Old February 26th, 2011, 07:44 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
Hey all:
I made a bit more progress today. I was able to get the new engine mounts welded to the frame and got the drivers side upper shock mount welded on too.
Here are some pics
Started grinding the paint off the axle too, but have a bit more work to do there before I paint it. Plus I think its too cold to paint it right now anyway. Hopefully it will warm up some soon and I can paint the front half of the chassis again too.
Daniel
ID:	36168   Click image for larger version
Old February 26th, 2011, 07:56 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
Here is how the axle looks so far. I redid my lower shock mount that I posted up before. This is some square tubing with the top part of a ford upper shock mount welded to it. I'm much happier with the appearance of this one. Plus its not crooked!
Daniel
ID:	36172   Click image for larger version
Old February 26th, 2011, 08:22 PM
Looking good!
series
Coil Series truck build TDI Guy Truck Build-up's & Restores 111 April 27th, 2013 11:15 AM
Adapter plate for series 1962siia88 Series Technical Discussions 7 September 8th, 2010 01:16 AM
series v8 build help orionpco Series Technical Discussions 32 July 18th, 2010 10:11 PM
Hopefully the LAST build update! DiscoDino Defender Technical Discussions 8 June 25th, 2006 04:58 AM
