series build update - Page 12 - Defender Source
Old October 7th, 2012, 04:00 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
Well I got the basics of the accelerator pedal install done and it fits fine for me. I built a small bracket to hang the pedal from out of square tubing. It bolts through the foot well. I reinstalled the brake pedal tower. Drilled a hole for the stock gm throttle cable (actually enlarged an existing hole). Made a small piece out of angle bracket that ill weld to the pedal to hold the end of the cable. Here are pics if how it will fit.
ID:	58643   Click image for larger version
Old October 8th, 2012, 08:39 AM
TeriAnn's Avatar
TeriAnn
Teriann Wakeman
1960 Dormobile
OK, I see what you did now. From your previous pictures it didn't look like you had the space to do it. Thanks for the new ones. I had forgotten that there were a couple inches between the bell housing dish on the bulkhead and the pedal. I have an insulation layer under the stock interior hardura layer so that space is taken up and no longer apparent. I had to go back and look at my installation pictures to see it.
Below is a picture of my installed Defender pedal in the stock Series location. I used an early 1990's Mustang 5.0 throttle cable and needed to add spacers to get the cable housing to cable eye spacing correct for the application.
ID:	58684   Click image for larger version
TeriAnn
Old October 8th, 2012, 12:08 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
Good point as per usual Jeff. The steering column is all done and can be installed easily. I should probably install the drivers seat too. I'm planning to heat and bend the shifter then trim it down as needed. My hope is to mimick the looks of the stock shifter.
I actually had a rhd shifter installed on my rig before so I'm used to it being a bit of a reach. That was a classic example of my laziness. I must have three or four proper shifters laying around and never swapped it out.
Daniel
Old October 30th, 2013, 10:43 PM
Robert those attached fine. That's quite a beast! You should start a build thread and share more details.
Daniel, how's the build coming?
Originally Posted by pendy
I'm here for the D's
Old November 2nd, 2013, 05:12 AM
aka rover's Avatar
aka rover
ed angel
95 D90
Looking great !! I'm ready to start my next build and the Chevy power is getting me motivated ..
85 D110 3.5 3 DR
Old March 20th, 2014, 06:55 PM
shoefnik's Avatar
shoefnik
Brian Horner
SIII 6.0L Vortec/4L65-E/Automatic
Daniel,
Any updates to your truck? Will it be ready for Mendo XX?
;o)
Old March 21st, 2014, 09:52 PM
Robert, I made a thread for your build here:
http://www.defendersource.com/forum/...ad.php?t=52521
Old July 9th, 2017, 08:26 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
ZOMBIE THREAD REVIVAL!!!
Hey folks. Long time no progress. My poor series project has been stalled for years. I moved and left the rig at my old place over a year ago, but it's moving home this week. A friend built me a gas tank and I just picked it up so the plan is to get back to work on this thing!! Hoping to move it to Sonoma County next week sometime and start making real progress on it asap. It's been so long I can't even remember what I have to do. I'll start by cleaning everything, going through the pile of stuff in boxes and ordering a bunch of new parts I know I need. Hoping to get it running by years end.
My goal is to have it ready for a trip to Baja in January.
Old July 9th, 2017, 09:37 PM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
So, this is a Series with an LS getting swapped in?
Old July 10th, 2017, 12:14 AM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
Yup. 5.3l from a suburban, chevy NP435, suffix B series t case, santana OD, 4.14 gears. Like I said its been so long I dont really remember whats left to do, but I'll get a handle on it as soon as I get it home.
Old July 10th, 2017, 12:40 AM
cowboy
steven
<drool>
Old July 11th, 2017, 09:02 AM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
Assuming all goes to plan the series will be home tonight! Woot!
Old July 12th, 2017, 11:35 AM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
Got it home in one piece! It doesn't look to bad after a bath. Not sure why pics are sideways.
ID:	268570   Click image for larger version
Old July 12th, 2017, 12:13 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
too cool!
~ Semper Fidelis ~
Old July 12th, 2017, 02:50 PM
You will roast like rotisserie chicken in that thing. No way can you move all that heat out of the engine bay fast enough.
I suppose you can heat shield it as much as possible but that right foot of yours is going to cook!
Old July 12th, 2017, 05:14 PM
cowboy
steven
Solutions? Same problem if it were a LS-era V6? I ask bc I'm very interested in buying a 109, but I'd rather have a worthwhile & doable engine upgrade scenario worked out in theory b4 I buy one.
Old July 12th, 2017, 09:00 PM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
Hi Bill
Glad to see you're still here. I'm sure it will get hot when I get stuck in traffic just like it did with the 2.25 only worse, but I've driven several different rovers with this exact same set up and I have never noticed excessive heat as a problem. Have you ever driven one with a set up like this and had that problem? Thanks.
Old July 16th, 2017, 06:26 PM
When the 109 was sporting the (big block) V8 years ago, it was an oven. I had the exhaust going from inside the frame rail to outside just behind the bulkhead.
The left cylinder bank was about 1/2 inch from the footwell. It sucked.
I will say that as long as you are moving more than like 25 its not so bad. Going slow on trails, not so much.
I'm sure that your experience will be different so pay no attention to my ramble....
Old September 20th, 2017, 01:27 PM
conrad1468's Avatar
conrad1468
Cory
1962 2A 109 Station Wagon
Awesome build! Great job!
Old October 4th, 2017, 06:25 AM
mwrms16's Avatar
mwrms16
Alex Martin
Series 2
This is awesome!!! Very good job!
Itīs a shame that we canīt do this things here in my country.
series
Coil Series truck build TDI Guy Truck Build-up's & Restores 111 April 27th, 2013 11:15 AM
Adapter plate for series 1962siia88 Series Technical Discussions 7 September 8th, 2010 01:16 AM
series v8 build help orionpco Series Technical Discussions 32 July 18th, 2010 10:11 PM
Hopefully the LAST build update! DiscoDino Defender Technical Discussions 8 June 25th, 2006 04:58 AM
