Series 3 wire harness - Defender Source
Old June 5th, 2010, 03:19 PM
bcourtney's Avatar
bcourtney
Robert Courtney
1973 Series III 200TDI
I have three things I can't figure out on my new harness.
First picture is blue with red tracer which should be dip beam. I already have one to the switch so not sure what this is. Not big enough for an indicator lamp.
Second and third picture is red with yellow tracer and black in a plug behind dash and plug and terminal ring on engine side of bulkhead. Can't find this combo anywhere on the electric diagram.
Also is there a reverse light circuit, don't see that either but I have green with black at both back corners but not sure where the switch wire would be.
ID:	28291   Click image for larger version
Old June 5th, 2010, 11:13 PM
Why do you think it is not big enough for the indicator light? There should be to the lights, to the switch and to the indicator aka warning light.
The red with yellow tracer is supposed to be the fog light switch to fog light or front fog light fuse to fog lights.
These are my secret weapons (lucas or british wiring color codes).
http://www.expeditionlandrover.info/Lucaswirecode.htm
http://www.dimebank.com/LucasColours.html
Old June 6th, 2010, 04:34 PM
bcourtney's Avatar
bcourtney
Robert Courtney
Thanks Ron, very helpful.
Old June 7th, 2010, 12:02 AM
Glad you enjoyed them.
series
94 D90 wire harness & 94 A/C wire harness mdmuf Wanted 1 August 24th, 2007 09:33 AM
Do I have a trailer wire harness or not!! P1CR Defender Technical Discussions 2 April 7th, 2004 07:54 PM
