Series 3 roof leak. - Defender Source
Old September 29th, 2015, 11:38 AM
seanman
Sean McLaughlin
Just purchased a 72 Series III....
Series 3 roof leak.
Hello all...
Just purchased my first Series 3, and am loving it! I do have a bit of a leak, from what I think is between the Galvanized drip rail, and riveted on aluminum roof... Read a few places that suggest using self leveling seam sealer... I've heard about 'Tiger Seal' and 'Sikaflex' as a couple options. Was wondering if you all had any advice?
thanks!
-Sean
Old September 29th, 2015, 12:18 PM
umbrella?
Old September 30th, 2015, 11:03 AM
WildBoar's Avatar
WildBoar
Derek Borror
109 withdrawals filled by a 110
I have a similar issue on my SIIA 109. Over the winter when I break it down for an engine transplant I am going to use a role plumbers putty on metal to metal contacts on my top where the the existing gaskets or additional gaskets don't or won't meet. There is some other term that folks use the same type of material for...monkey puddy or something like that.
"I think we are good...its still dripping"
Old September 30th, 2015, 11:56 AM
There some 3M type stuff like that.
Old September 30th, 2015, 03:54 PM
Tom109
Tom P.
1965 ExMoD 109, 1995 RRC LWB
The issue is the joint between the steel gutter, aluminum roof, and stretched rivets. You can try seam sealer, but ultimately you'll need to separate the gutter from the roof. Clean and prep them both really well, then use a strong adhesive/sealant when you re-rivet. I used about 170 rivets on a 109 roof, and sealed with 3M 5200. Been fine ever since...
Old October 1st, 2015, 12:14 AM
seanman
Sean McLaughlin
Thanks Everyone!
Tom... with the 3M 5200, you used it between the Galvanized and Aluminum before you riveted...Did you also put a layer on top of the rivets from the outside afterwards?
thanks again everyone for the advice!
-Sean
Old October 1st, 2015, 08:10 AM
Tom109
Tom P.
Sean,
My roof had about 1/4-inch of "stuff" built-up between the roof and gutter channel form PO attempts to seal it. I disassembled everything and cleaned it. I drilled the holes out to 3/16 (one size up form the factory rivets) and ordered a few hundred semi-tubular rivets - I'll have to look and get the correct length for you.
Back to your question, yes, I used the 5200 between the aluminum roof and galvanized gutter, then re-riveted before it set. It is a messy process, and you'll never get that stuff off clothing, but I was able to do this all by myself. Afterward I used a paintable seam sealer in the actual gutter channel.
Tom P.
roof, series
Series III 88 roof, roof sides and rear door jgrear For Sale - Parts 1 February 25th, 2015 09:47 PM
Coolant Leak Discovery Series II aosias Series Technical Discussions 3 January 25th, 2010 12:04 PM
Safety Devices D90 Rear roof rack ladders and ECR roof baskets ECR The Vendors Loft 27 May 6th, 2009 10:23 AM
roof rack and a hannibal roof tent on a ST 90? DonFromWhitby Defender Technical Discussions 6 March 17th, 2009 09:02 AM
I think I fixed my SW roof leak problem BarryO Defender Technical Discussions 12 November 20th, 2006 08:01 AM
