Series 3 ingnition switch and signal stalk clamp locations? - Defender Source
Old June 2nd, 2010, 12:58 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
It seems the one thing I did not take photos of while disassembling was my dash. If someone could shoot a close up of the steering column with the top plastic shroud removed it would be most helpful. I am trying to figure exactly how the 2 clamps for the ignition and signal stalk are oriented.
Old June 10th, 2010, 04:01 PM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
From what I remember from mine, the indicator sits in a groove on the end of the column (the indexing tab on the indicator sits in the groove at 3 o'clock). I believe the ignition sits in the other groove, at 9 o'clock, a few inches back or so. Here are a couple pics that may not help you, but I had them sitting around on my hard drive from the day I bought my SIII.. Sorry I can't take any more pictures, but my vehicle is now an atrocious monstrosity of both series parts and D90. I'm using a 300tdi column now (I think), that I made work with my indicator and ignition..
ID:	28436   Click image for larger version
lamp, series, signal, switch
Turn Signal Failure arbik Defender Technical Discussions 53 October 11th, 2010 10:51 PM
Turn Signal switch may be shot- scout159 Defender Technical Discussions 2 March 11th, 2010 08:09 PM
95 column stalk cluster complete FS SafariHP The Vendors Loft 3 May 1st, 2008 08:28 AM
Turn Signal probs mspell Defender Technical Discussions 7 November 5th, 2004 05:19 PM
Need Turn Signal Switch 48vphantom Wanted 1 September 24th, 2004 02:18 PM
