Series 3 gearbox problem - Defender Source
Old March 27th, 2012, 10:36 AM
cabell's Avatar
cabell
Cabell Crowther
I have finally gotten around to working on a barn find series 3 that I've had for a while. When purchased (P.O. expired) the top cover was loosely fitted to the gearbox and a few springs and detent balls were missing. I got those replaced, repositioned the slector shafts and still have no 3 or 4th gear. Is this a syncro issue, selector shaft adjustment or what? The slector shaft seems to travel the appropriate distance and 3rd seems to try to engage with a little grumbling. Fourth doesn't even try. Pops out of second on over-run. 46K on the truck.
Old March 28th, 2012, 04:28 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Before putting it back together did you make sure the selector forks were correctly installed. i.e, not behind or in front of the gears?
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old March 28th, 2012, 08:21 AM
synchor springs on 3/4 hub may be gone or broken. for the 2nd gear issue try adjusting the 1/2 shift fork one RCH closer to second gear. If you go too far then first will start popping out.
Old March 28th, 2012, 09:49 AM
cabell's Avatar
cabell
Cabell Crowther
Tom, I'm pretty sure I have it in the correct spot but will check it again. Dave, is the spring replacement something that can be done with gearbox in-situ?
Old March 28th, 2012, 01:13 PM
yes. you need a really long pair of needle nose pliers.
series
5 speed gearbox on a series 3 Land Rover with a 2.25 stock petrol engine? gabrielochoa Series Technical Discussions 6 November 20th, 2011 11:38 AM
Series IIA gearbox mattm For Sale - Parts 0 September 25th, 2010 06:06 PM
Series II (suffix A) Gearbox jaygoss For Sale - Parts 1 August 26th, 2010 04:37 PM
Maya Culpa series 3 Question about main shaft slop in gearbox airbornrover Series Technical Discussions 2 May 21st, 2009 08:09 PM
