Series 3 clutch push rod too short ? - Defender Source
Old May 12th, 2011, 01:37 PM
kjva
Ken Jackson
1985 110 Wagon
Just put a new flywheel, pressure plate, friction plate, throwout assembly, new master and slave cylinder and found the throwout assembly will not travel far enough to engage the pressure plate. On the UK forum was told to add around 20mm to the clutch push rod. Has anyone else had this problem ?
Old May 12th, 2011, 10:44 PM
Previous owner did that on my SII.
Not sure why it was necessary, but it works!
Old May 17th, 2011, 08:40 PM
check your m/c pushrod adjustment to make sure there is not too much free travel you want about 1/16" max free travel in the pushrod itself. also make sure it is properly bled and that the flex hose is not gone soft.
clutch, series
Early series clutch mech D90user Series Technical Discussions 3 February 28th, 2011 03:36 PM
1981 Land Rover Series III Diesel Short Wheelbase in Phila jessejames4 Misc. Chit-Chat 2 January 26th, 2008 09:55 AM
Series IIa short wheel base TDI Guy Wanted 3 August 12th, 2004 01:15 PM
