Series 2a front light plinth - Defender Source
Old April 16th, 2013, 09:34 AM
Does anyone know of a source for just the plinth for the early 2a style front turn signal light - the kind the lens just pushes into the rubber housing?
RN has the whole assembly, but a bit pricey and I haven't gotten my $500 yet
http://landroverparts.roversnorth.co...px?code=532806
Originally Posted by pendy
I'm here for the D's
Old April 16th, 2013, 09:51 AM
Some creativity and the cheapo plastic ones and Bob's your uncle. You need to use the original boot though.
Old April 16th, 2013, 10:18 AM
If you mean stick the innards of the cheap plastic one into the original boot/housing, then I like it. Effectively all that is wrong is the bulb holder is failing.
Old April 16th, 2013, 10:22 AM
Yup. Ron good. Keep in mind I did this 15 years ago and don't remember exactly how I did it.
Old April 16th, 2013, 10:52 AM
gambrinus
Russ Wilson
1965 Dormobile
Holden in the UK or RN... you're still looking at approx $50 with the conversion and shipping.
Old April 16th, 2013, 10:53 AM
Triple C has the rubber boot only for $6.95 each here
Bulb holder here
These are reproduction, of course.
Old April 16th, 2013, 10:54 AM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
Charles -
I have some extra Series III style - whole light assembly including rubber base and lens. Some brand new in bags, some used - red, white, and amber.
I know they are different from what you are looking for but I thought I would mention it anyway.
Firemanshort
1980 Stage One 109
Sterling, VA
Old April 16th, 2013, 10:58 AM
I need to check if it's single or double filament, but I need the L594 style. I only need the socket, so it looks like these would do it
http://www.s-v-c.co.uk/product/l594-...-twin-contact/
Thanks!
Old April 16th, 2013, 11:05 AM
The Dro
Dro
1988 Ninety
Didn't you get my email??? Triple C has them.
Old April 16th, 2013, 11:06 AM
Bill, just saw your post - I might try triple-c, thanks.
Dave, i just case about keeping the same lens/ring so if your holders would work with them then I am interested. Did you get your bleeding done yet?
Old April 16th, 2013, 11:07 AM
I have gotten several emails from you this morning, but not one about this
Old May 6th, 2013, 11:05 AM
The Dro
Dro
1988 Ninety
Charles,
Found another company that sells the Series Front Lamps.
http://jollyrogersmotors.com/node/268
http://jollyrogersmotors.com/node/282
Old May 6th, 2013, 09:45 PM
This fell through the cracks and I never ordered one, but plan to get one from triple-c since I just need the bulb holder. Big price difference to buy the whole thing from jollyrogers.
Old June 5th, 2013, 11:50 AM
I ended up getting one from triple-c. There was a slight difference in one if the terminal connections but other than that I'm very happy with it.
Old June 5th, 2013, 12:13 PM
The Dro
Dro
1988 Ninety
Kool.
Do they look like the original ones?
Old June 5th, 2013, 05:43 PM
The bulb holder (which is all I got) is not visible anyway but looked the same.
I was on my phone earlier and didn't want to go into detail, but the difference was that the center terminal was also a bullet connector for the triple-c one and the one I was replacing was soldered or crimped on to the little post in the center. I am not sure if what I had was unusual or not, but figured it was worth noting.
ht, series
fitting a series front end on a defender Apocalypse Vehicle Defender Technical Discussions 13 September 9th, 2011 04:04 PM
NAS 110 Front Defroster Light bjf Defender Technical Discussions 7 January 14th, 2010 01:43 PM
Front Light Bar wanted Joe_in_OH Wanted 1 January 1st, 2010 04:28 PM
how many forum members does it take to change a light bulb? brn24whl Misc. Chit-Chat 14 December 4th, 2009 09:07 AM
Series Rover front & rear bench seats jvelador For Sale - Parts 6 April 14th, 2008 06:41 PM
