Series 200TDI radiator reservoir - Defender Source
Old September 16th, 2012, 08:53 PM
bcourtney's Avatar
bcourtney
Robert Courtney
1973 Series III 200TDI
Been trying to figure out the best set up for a reservoir in my Series with the 200TDI. Best I can come up with is this Defender V8 one, but what do I do with the 5/8 return on the bottom. Pretty sure in the V8 it tee's back into a heater return line, but the only way to mount it in the Series bay puts it lower than the heater line. Any suggestions?
Old September 16th, 2012, 09:55 PM
Are you absolutely set on using Rover parts or are you open to other options?
Old September 16th, 2012, 11:44 PM
Naplm00
Matthew
You could just use the stock "y" hose made for the defender 200tdi. It would just splice it in to the W
Waterpump feed
Old September 17th, 2012, 08:24 AM
Yes it normally tees into the lower rad hose.
Old November 21st, 2012, 06:33 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Yep, that's where it goes.
Mike Hammond
Old November 21st, 2012, 07:28 AM
That would be a better solution than putting a bolt up the line and clamping to tight to avoid leaks.
Old November 21st, 2012, 08:43 AM
mikeslandrover
Mike Hammond
The expansion bottle should be mounted so that the filler cap is slightly above the level of the radiator that way air will collect in the expansion bottle not the top of the radiator. The hose from the bottom of the expansion bottle is Tee'd in the the bottom radiator hose that returns coolant to the engine.
You don't want to be overheating that engine.
Mike Hammond
200tdi, radiator, series, tdi
Leads ona rebuilt 200tdi or any Series engine? jvelador Wanted 0 May 6th, 2011 11:17 AM
Series Parts Scored from Lybia SafariHP The Vendors Loft 0 March 5th, 2011 07:54 AM
Adapter plate for series 1962siia88 Series Technical Discussions 7 September 8th, 2010 01:16 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
