Series 1 compatibility - Defender Source
Old December 10th, 2013, 01:39 AM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Been researching about the Series 1, seems parts are difficult to come by. Which lead me to question if there are compatible series 2 parts that could be used on the Series 1 88" when parts dry up?. I know that some S1 owners convert to the 2.25 L engine, but is it compatible with the S1 trans?. Also some parts like the swivels, diffs , front props shaft (but not rear), can also be interchanged it seems, but not axles, 1/2 shafts? While desirable to keep an S1 original, seems that very soon S1 owners will have no choice but to use non S1 parts. I haven't seen anything clear on the S1 compatibility with the other Series..
Old December 10th, 2013, 05:12 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
The transmission is slightly different in that it has a manual clutch. I have been converting some of them over to "C" suffix by remaking the bell housing with the correct blend of parts and a machined hole on the bell housing (if its a LHD) or RHD can use the standard part.
I have a pretty good stack of 2.0 motors from my early series II junkyard (same motor as the SI) but generally people have been opting for the 2.25 purely out of cost considerations.
Axles I can custom make after I run out of used.
Diffs are common to both. I make my own driveshafts.
Matt Browne
Old December 10th, 2013, 08:50 AM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
Originally Posted by junkyddog11 View Post
The transmission is slightly different in that it has a manual clutch... .
Ummmm, maybe "mechanical" clutch?
Old December 10th, 2013, 09:15 AM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Good info!. Manual clutch? as in external linkage vs internal?, then the bell housing would have to be switched to later type S2 because of bolt pattern if one decides to go to the 2.25, or convert the old S1 bell housing.
It also seems that the 2.0l engine internals are pretty much the same as the 2.25L but more susceptible to valve and crankshaft wear than the 2.25L.
The only problem I see with upgrading is the down grading of the original S1 with non original S1 components, which is a dilemma I guess based on use or show..
Old December 10th, 2013, 11:49 AM
Body panels seem to be the worst to find IME. Took forever to find decent 80" doors. The cost of a proper rebuild of a 1.6/2.0 engine is astronomical. I like Ike's 4 cylinder MB powered 80in shop truck.
That said, I am thinking about parting ways with my long term parts hoarding of my 80in stuff as I will never get the time to put it all together and, even if I did, I am too tall to drive it comfortably (not that I drive my SII ....)
Old December 10th, 2013, 11:55 AM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
What is the average cost for rebuilding a 2.0L and why? seems the parts are pretty much same as the 2.25L
Old December 10th, 2013, 12:03 PM
Parts are completely different between the two engines and the parts are rare and expensive (like $150 a valve seat expensive). If you are talking 2.0 diesel in an SI, the parts are similar but the last running one I knew of died like 5 years ago.
Old December 10th, 2013, 12:09 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
[QUOTE=evilfij;489476]Parts are completely different between the two engines and the parts are rare and expensive (like $150 a valve seat expensive).:
Damn.. Now I know why peeps in the US opt for the 2.25L
Old December 10th, 2013, 09:21 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
You dont happen to have the rear tub, do you?
A friend up in PA might be in need...
Rent my
Old December 10th, 2013, 09:27 PM
Last I heard I thought he was all set with that?
Old December 11th, 2013, 02:39 AM
I think Steve got it sorted.
Old December 11th, 2013, 04:56 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
Yes, mechanical…..the word I was searching for vs the hydraulic system in later yrs. Yes the bell housings have to be swapped………in fact there is a whole bunch of swapping and making bits. To be honest I can't tell you what I did without researching my own work lol. I do know that there are a couple of SI's out there with Suffix C transmissions in them that I put there, both of them are 88" wheelbase, as are (oddly) most of the SI's I see on a regular basis.
If anyone want 2.0 engines I have probably a half dozen that are useable as in not frozen and complete.
Matt Browne
Old December 12th, 2013, 01:07 AM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Thanks for the info, I'm keeping notes for future use as I learn more about the S1 88"
Old December 12th, 2013, 02:16 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Don't make me post that video... Ouch!
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old December 12th, 2013, 08:06 AM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Post!, post!
Old December 12th, 2013, 08:03 PM
1953lr80's Avatar
1953lr80
Jeremy
'51 80", RRC, LR3
Series 1 parts
Series 1 parts 'compatibility' is an interesting topic in building an NAS 1951 80" from an incomplete basket case. Using Series IIA (1966) engine and axles having previously rebuilt a 2.0 liter in a 1952 80". Outwardly trying to preserve all the 80" characteristics (through-the-floor pedals, instruments, 1.5" rear springs, etc.). 80" parts are not easy to find.
Jeremy
Name:	1951 80 Dec 2013.jpg
Old December 12th, 2013, 08:41 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Jeremy
I would imagine the 80 series would be the most difficult to find parts for.
Old December 12th, 2013, 09:15 PM
Thankfully Jeremy lives about 20min from me ....
Old December 13th, 2013, 09:06 AM
1953lr80's Avatar
1953lr80
Jeremy
'51 80", RRC, LR3
As evidenced by the clutch withdrawal housing, bumper, and bulkhead grab bar and steering column support so far . . .
Old December 13th, 2013, 09:43 AM
Is that the truck Al Richer was selling?
series
WTB series 1 ton transfer case (or 1.53:1 gear set for series tcase) cgalpin Wanted 3 March 7th, 2013 09:54 AM
Series Parts Scored from Lybia SafariHP The Vendors Loft 0 March 5th, 2011 07:54 AM
Adapter plate for series 1962siia88 Series Technical Discussions 7 September 8th, 2010 01:16 AM
Conatiner Arrival means Defender / Series Parts Clean Out SafariHP The Vendors Loft 18 December 5th, 2008 09:38 AM
