Seat belt brackets don't let door completely shut! - Defender Source
Old December 12th, 2013, 09:33 AM
WildBoar's Avatar
WildBoar
Derek Borror
109 withdrawals filled by a 110
Not sure these are the correct seat belt brackets as the don't allow my front doors to shut. If they are the wrong ones I don't want to try to modify and impact the structural integrity. Any recommendations?
ID:	85967   Click image for larger version
"I think we are good...its still dripping"
Old December 12th, 2013, 10:15 AM
The originals had seat belts strap integrated to the bracket not bolt on so there looks to be something odd to start with.
This is the replacement type I have on mine
http://www.roversnorth.com/ProductDe...=345100&type=0
Old December 12th, 2013, 10:32 AM
Looks like they are in wrong handed. That one is the right side I think. The other thing is that the shoulder bolt should run in a lot more so it is not sticking out and the anchor plate pivots in the shoulder and not the threads. There's supposed to be a flat washer and a wavy washer under it.
The socket head cap screws aren't helping either. If you must have a socket head, maybe swap for button head. Otherwise, hex heads are best along with good washers.
Old December 25th, 2013, 11:35 PM
WildBoar's Avatar
WildBoar
Derek Borror
Thanks folks. I will experiment with moving things around and using smaller fastener heads to see if I can get some clearance.
Old December 27th, 2013, 11:22 PM
Yes the longer surface bolts down to the seat box and the shorter to the front of the tub. And just use hex bolts like the factory did.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old December 28th, 2013, 12:42 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
The belts have been replaced with incorrect parts.- jason is correct. The original part is below the new part, the originals were sewn in and they just bolted a new one into the bracket...
Any good supplier will have the correct belts in stock (we do but are closed this week and there should be a couple good guys close to you)
Bench Seat & Seat Belt Bracket Feeler jefhuf For Sale - Parts 35 August 30th, 2010 11:01 PM
Rear Seat Belt Brackets founD90 Wanted 21 August 19th, 2010 09:25 PM
Rear Seat Belt Brackets zed111 Defender Technical Discussions 11 August 6th, 2007 02:45 PM
Lap seat belt for the rear - flip up seat paulb Defender Technical Discussions 2 January 27th, 2005 03:43 PM
Side Brackets for Rear Bench Seat & Rear Seat Belts zed111 Wanted 2 August 16th, 2004 12:33 PM
