Seafoam? - Defender Source
Old June 14th, 2015, 03:01 AM
Surf90's Avatar
Surf90
C.S.
1989 Defender 110 200tdi
Seafoam?
I'm having trouble passing ca smog due to high carbon levels. Anyone used seafoam to clean out a series motor? Any tips or wisdom?
Old June 14th, 2015, 06:05 AM
Crash303's Avatar
Crash303
Josh Harris
97/ D90 ST #1190
When was it's last good tune up? Some fresh oil, new spark plugs/wires/cap and rotor will do a lot of good.
I have used Seafoam and it works well. Do the seafoam and then do a tune-up.
When the F*%# did we get Ice cream!!!
"They are, in factory original condition, noisy, they leak water in from the top and oil out from underneath, you can never demist the windows in winter, they handle like scaffolding towers, and use more fuel than Beijing." Richard Hammond
Old June 14th, 2015, 07:29 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by Crash303 View Post
When was it's last good tune up? Some fresh oil, new spark plugs/wires/cap and rotor will do a lot of good. I have used Seafoam and it works well. Do the seafoam and then do a tune-up.
IMO, One shot of seafoam will probably not do magical things but a proper tune and clean fluids should give you a shot. Years of dirty fluids can not be reversed with seafoam alone. It's like asking a hotel maid to come in to your frat house on Monday with a paper towel and a can of pledge and expecting measurable results.
Old June 14th, 2015, 11:01 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Could be your cats and or the flame trap causing the high carbon levels. Also make sure to rev your engine at 2000 rpms when your waiting in line that will help heat up the cats to lower the carbon levels.
Old June 14th, 2015, 04:59 PM
Surf90's Avatar
Surf90
C.S.
Thanks guys. I have all fresh and clean fluids in it and it runs very strong seemingly well. I don't think it needs a tune up, but we'll see.
------ Follow up post added June 14th, 2015 02:00 PM ------
Oh and it has new plugs, cap, and rotor all in the last year.
Old June 14th, 2015, 06:16 PM
Grover's Avatar
Grover
You must have lived in a fraternity house...lol
Old June 14th, 2015, 07:52 PM
Surf90's Avatar
Surf90
C.S.
Did you guys use a vacuum line? If so which one? I've got a 2.6 L petrol
Old June 16th, 2015, 03:19 PM
asetliff's Avatar
asetliff
Adam Setliff
2A 109 Four Door 07 RRSC
I can't tell you what vacuum line but I can tell you to pour it in slowly when you do find it. My disco 1 starter was cracked by a hydrolocked engine using too much at once.
I don't know if it works but I've heard people jump on this snake oil as well.
http://www.amazon.com/gp/aw/d/B000CIPUR8?vs=1
Old June 21st, 2015, 02:48 PM
Hydrocarbons (HC) or Carbon Monoxide (CO)?
Don't waste a penny on seafoam.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old June 21st, 2015, 04:02 PM
toad's Avatar
toad
Cutter
A 2.6... getting an engine that they started making in '48 to pass emissions in CA is going to be a big hurdle. Good luck. Does it have the european air/exhaust injector pump setup, that would maybe help since it was designed to pass stricter western european standards (mind you in the 70s)
Old June 22nd, 2015, 12:57 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
I've basically only used Seafoam lately to check for exhaust leaks.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old June 22nd, 2015, 01:12 PM
SonnyAK's Avatar
SonnyAK
Sonny
1993 NAS 110
I've used the Seafoam (Fuel additive one) several times, and I thinks it's helped clear out our rougher running Bronco, but I'm not sure if it'll help enough to pass a smog test. That said, I think it's one of the only fuel additives that actually helps a bit! I guess you can always give it a shot and let us know how it goes.
Old June 22nd, 2015, 01:24 PM
Surf90's Avatar
Surf90
C.S.
Originally Posted by Ren Ching View Post
Hydrocarbons (HC) or Carbon Monoxide (CO)? Don't waste a penny on seafoam.
CO levels
------ Follow up post added June 22nd, 2015 10:24 AM ------
Yeah there is no chance this engine would pass alone, but with the LPG conversion it burns a lot cleaner. Just not clean enough apparently
Seafoam Chris Cox Defender Technical Discussions 13 September 13th, 2004 10:05 PM
