School me on leaf spring bushings - Page 2 - Defender Source
Old August 27th, 2010, 08:35 PM
UnfrozenCaveman's Avatar
UnfrozenCaveman
Keith Armstrong
Various
Date, schmate.
I hear there's a guy who wants to know about spring bushings????
Anyone here know about those?
Old August 27th, 2010, 11:44 PM
Preferred removal method on old bushings is the propane torch. With the spring removed and the bolts out, point your Bernz-o-matic down the hole and hold it there until you get it good and hot. The rubber will begin to fizzle at which point you should be able to push the inner part of the bush out. Now all that's left in there is rubber and the outer shell. Dig out the rubber. Remove outer shell by sawing carefully with a sawzall until you are through the shell. Cold chisel removes the shell.
Old August 28th, 2010, 10:06 PM
Don't breathe the fumes from the bushings though. We are talking level 10 bad for you.
Old August 30th, 2010, 02:59 PM
Jeez, that explains the backing out every Saturday night.
Old August 30th, 2010, 03:30 PM
It explains a lot of things
Old August 30th, 2010, 03:54 PM
Old September 1st, 2010, 12:34 PM
Mark McDonough's Avatar
Mark McDonough
Mark McDonough
66' IIa, 95 D 90 300 Tdi, 94,98 D1
C-Clamp
If you use plenty of anti-seize on the OD of the new bushings when fitting back in place you'll have a much easier time with maintainence on them- both pushing them out and pushing them in the next time. I use a
C-clamp device with a pretty heavy screw on it and a turning handel thats like 1/2 inch in diameter. Basically all you do to install is, first clean up the ID of the bushing carrier with scotch pad till it's nice and honed. Then lather up the ID of the bushing carrier on the spring with anti-seize, then set the end of the C-clamp on the end of the bushing and start turning. If alignment is good, you should be able to drive the bushing home without concern of mushrooming the OD of it. Removing a bushing thats been put in place with this method is also pretty easy. Pull the bolt, drop the spring, place a piece of 3" piping with ample clearence in it's ID for the bushing to be pushed into, and with your C-clamp in place, heat up the bushing carrier on the spring ever so slightly. Begin turning and in 2-3 minutes you'll be ready to install new bushings again. I also advise sticking to OEM bushings. Much of the cheap shit out there is made of material that is hydroscopic. That is, it absorbs water.
Old September 1st, 2010, 01:35 PM
It is **WAY** easier to install and remove the bushing from the springs themselves than it is from the chassis. The reason being that the spring bushing eye is open on side. Nowhere near the resistance to fitting as with the solid eyes in the chassis. I have used a big Snap-On air chisel to drive chassis bushes in, that actually worked pretty well. These days I just put it off until I'm older. There are better ways to spend a Saturday
Looking for a good deal on a bushwacka tool if anyone has seen them. They never seem to come up.
bushings
DAP bushings jorge Defender Technical Discussions 5 April 18th, 2005 08:39 PM
Need D1 rear spring perch James Wanted 1 April 3rd, 2005 12:29 AM
Body bushings - poly or factor rubber?? jaherring Defender Technical Discussions 15 February 10th, 2005 06:42 PM
Spring Isolators wicks Defender Technical Discussions 16 January 28th, 2004 02:37 PM
