Scary front suspension - Defender Source
Old December 17th, 2012, 11:40 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Yikes, this is the scariest series front suspension I've seen
http://cgi.ebay.com/ebaymotors/1973-...item3f2035fa1f
Old December 17th, 2012, 11:44 AM
The chassis is pretty scary too.
Old December 17th, 2012, 11:58 AM
skupetz
Gustaf Kupetz
NAS110, HCPU, Disco, Toylander, 2
front suspension
Ah thats nothing, I have a buddy who drove around lake superior with a frame like that, if you wiggled the front bumper up and down the whole front of the truck moved.
Easily drivable
Old December 17th, 2012, 01:43 PM
The front is clearly on a different plane than the rear is, so I'd assume the chassis is about to break in half, no?
Not sure I'd want to drive it daily:
Originally Posted by eBay ad
It is tagged and insured and gets driven daily.
It has running lights but no brake lights
The Rover will need new tires, the tires on it are very dry rotted
The brakes will need work. The rear brakes do not work and the front wheel cylinders have a slow leak
Name:	Series eBay 1.jpg
ID:	62843   Click image for larger version
Name:	Series eBay 2.jpg
Old December 17th, 2012, 01:49 PM
occasionally should be fine though .. it is Florida after all
Old December 17th, 2012, 01:58 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Kudos for the seller being honest about it with picture and description: "The frame on it is in bad shape"
Not so true for many ebay listings (the used car lots) out of FL where the rot is covered by Waxoil, tar, and a rattle can and the promise it is the most structurally sound frame around.
Old December 21st, 2012, 08:31 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Check out the pic of the spring hanger too!
Also, the ad says it's a '73... that "B" suffix is 1964 (although it /could/ have had an older plate assigned to it)
Old December 21st, 2012, 08:40 PM
87 D110 (Ruby)
that frame is SHOT...I wouldn't go near that if it was half the current bid price...that front frame horn is 1/4" from breaking right through!!!!
front suspension
D90 Passenger Front Fender (patch) ToyCrusher Wanted 4 February 25th, 2005 10:24 AM
Sliding down the slippery suspension slope souza Defender Technical Discussions 18 February 3rd, 2005 11:06 PM
Help: Suspension Suggestions gtg067i Defender Technical Discussions 29 January 20th, 2005 02:58 PM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
