Salisbury Carrier Bearing Question - Defender Source
Old November 8th, 2013, 04:38 PM
LR Max
Thomason, Max
1973 Series 3 109
Hi Guys,
My research indicates that the carrier bearings for a series salisbury axle should be the 382A and 387A. However when I pulled the 3rd member, the races said 382S.
Any idea on the discrepancy? If I need to get the 382S, then it looks like I'm driving down to Summit tomorrow morning
carrier
rear tire carrier question sirjond Defender Technical Discussions 4 September 9th, 2012 09:57 PM
Yet another tire carrier question kinetic Defender Technical Discussions 9 October 11th, 2011 06:20 PM
Salisbury Diff Bearing Part Numbers? Wolf Fabrication Defender Technical Discussions 4 June 13th, 2010 03:01 PM
LT230 questions and concerns - bearing failure. kiphartzell Defender Technical Discussions 4 January 13th, 2006 01:56 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
