S3 with V8, clutch issues - Defender Source
Old July 30th, 2014, 04:51 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Series 3 109 now has a small block chevy fitted. I've been tasked with tracing a noise from the clutch that only occurs when the car has been driven a little and everything is up to temperature. The noise is present the moment one lays any pressure on the clutch pedal and increases the noise the harder/further one presses on the pedal.
First thought is a failing throw out bearing but so did the customer who replaced the bearing recently for the exact same noise.
I have determined that there wasn't adequate free play at the pedal to the master push rod and figured that the clutch hydraulic fluid expanded from heat and caused some drag against the bearing, possibly contributing to the noise.
It is quiet if you are off of the pedal.
Tomorrow I am going to pull the slave cylinder and fit a shim between it's housing and the bell housing, like is normally found on a D90. (The oil filter has to come off to extract the cylinder, and dang, it's hot right there.)
Currently I can make the clutch slip with heavy throttle, and it's very possible that the lack of free play at the release bearing allows this to happen , or that the lack of free play wore out the new-ish disc, but my question for those that have fitted a SBC v8 to the Series transmission: is the stock Series Rover clutch good enough to handle the V8 power? I'd hate to take out the box and not fit adequate clutch parts!
I do not yet know if it's a 9", 9.5" or 10" clutch.
Email is
Same place, new dogs.
Old July 30th, 2014, 10:15 PM
transientmechanic's Avatar
transientmechanic
1972 SIII
Thank god the clutch is slipping. It's saving you from picking up transmission pieces from all over the ground.
Call Matthew Jackson at Advance Adapters and explain your predicament. He will be able to offer perspective. (He has a SBC in his Series IIA)
Old July 30th, 2014, 10:46 PM
LNBright
Leslie Bright
1972 88" SIII
A Series transmission is marginal for the stock powerplant; definitely not up for a SBC.... It's a wonder it's still holding together....
Old July 31st, 2014, 03:20 PM
Roverlab
Trevor Griffiths
Don't know who's adapter is in their- I'm batting clean up!
Never thought of a clutch disc as a "fuse" to protect the gears.....
Matthew helped me out last year with a 4BT powered 109, very helpful....
Email is
Old July 31st, 2014, 04:45 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Years ago when I started looking at series engine conversions and worked at the USCG Aircraft repair and Supply center, the reliability engineer analyzed the series transmission (both IIA and III).
The report was you do not want to put over 190 ft lbs of torque through a series transmission and maintain reliability. The GM 350 V8 has to put out at least 290 ft lbs of torque.
I think the front transmission bearing on the primary pinion has failed and rattles when the clutch is depressed.
RDavisinVA
Old July 31st, 2014, 05:14 PM
Roverlab
Trevor Griffiths
I don't hear any bearing noise "winding down" when the clutch pedal is depressed, like I would expect as the input shaft slows.
This morning, we fitted a spacer under the slave cylinder, drove the car the exact same way and duration as multiple previous test drives that consistently produced the noise, and it has not returned. No change in the ability to engage first gear at a stop. And, I would almost believe that the point in which the clutch begins to slip un-mercilessly is at a higher rpm/load. But, none of that changes the fact that the Series clutch likely was never intended to have this much torque and hp applied to it.
Waiting on a call back from the owner.....
Email is
clutch, v8
Clutch Master/Slave Issues Jackie Treehorn Defender Technical Discussions 25 July 11th, 2016 04:25 PM
Brake and clutch issues beast Defender Technical Discussions 5 January 13th, 2014 12:42 PM
Family trip delays, D90 having clutch issues Roverlab Misc. Chit-Chat 12 April 4th, 2013 09:51 PM
Lashcap issues/valve cap issues trybul Defender Technical Discussions 6 January 9th, 2012 12:46 PM
Clutch issues mspell Defender Technical Discussions 13 March 21st, 2005 11:45 PM
