S3 Power steering project - Defender Source
Old December 18th, 2014, 03:47 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Almost ready to put in fluid and power it up.
ID:	108910   Click image for larger version
Email is
Same place, new dogs.
Old December 18th, 2014, 07:06 PM
Ignotus
gene
1960 109, w/200TDI
Yer gonna love it! One of the best upgrades.
Gene
1960 109
1960 88 Ignotus
Blog;
Old December 18th, 2014, 09:51 PM
cbfritz_03
Carmen
none
That looks good Trevor.
Saw this one the other day that had been done recently. Seeing in person is sooo much more helpful to me than a picture. I wish I had been there to watch the whole process.
With things like this I'm one of those visual, hands on, show me once and I got it kind of learners. I need a class...
If anyone is planning to do one of these near me...let me know so I can watch?
Old December 18th, 2014, 10:22 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Can we see the pump/belt/hoses?
Nice job!
Rent my
Old December 19th, 2014, 09:09 AM
LRover's Avatar
LRover
J. Michael McCaig
Looks great! I too would like to see how you ran your hoses. I have my steering box installed but haven't run the lines yet. Were you able to keep the original steering wheel?
Old December 19th, 2014, 09:12 AM
transientmechanic's Avatar
transientmechanic
1972 SIII
Which steering shaft did you use? I am in the midst of this right now and can't figure out exactly which one I need to connect my 90/110 column to the P38 box
Old December 19th, 2014, 09:16 AM
Make one.
The U joints are readily available and the shafting is 3/4-48
Old December 19th, 2014, 10:14 AM
Roverlab
Trevor Griffiths
The upper column is two Series shafts welded up so we can use a standard steering wheel. The bearing end is machined to incorporate a standard sealed bearing with a spline for the Rover u-joint, and the lower column shaft between u-joints is fabricated.
Fabricated a bracket to mount a ZF reservoir above the box on the inside of the wing. Pump is a Bosch RR unit and the pulley is made of RR and D2 parts.
We still have some cleaning and detailing to do, but are waiting until we test run this afternoon to refit the wing.
ID:	108947   Click image for larger version
Email is
Old January 5th, 2015, 04:56 PM
transientmechanic
1972 SIII
Trevor, could you share the information on the fittings you used at the steering box? My P38 box came from the junkyard with no fittings... need to build lines soon
Thanks!
Old January 5th, 2015, 06:02 PM
oilburner's Avatar
oilburner
JL
large pile of parts
They are just banjo fittings, metric, same as you would find on a BMW or other German car. I think it is M18X1.5 and M16X1.5 thread.
JL
Old January 5th, 2015, 07:26 PM
Roverlab
Trevor Griffiths
Adam, I'll post the part numbers I used when I get back out to the shop tomorrow.
Email is
Old January 6th, 2015, 09:27 AM
Roverlab
Trevor Griffiths
These are the parts I ordered from the likes of Jegs and ANPlumbing.com:
2x 555-110021 90* -6
1x 555-110022 90* -8
1x 555-110910 -6 hose
1x 799-632103 -8 hose
1x 799-632203 -12 hose
1x 361-AT991955 -6 to 16mx1.5 adapter (for P38 pump p/n QVB101090)
1x 776-06-M14D banjo
1x 776-08-M16D banjo
2x 89142015 alloy washer
2x 89162215 alloy washer.
Hope this helps! We've had the Rover running and confirmed function in the shop with no hydraulic or clearance issues. Well, it's a rover so there are other unrelated issues such as no idle mixture adjustment on the carb. As soon as we resolve that and the dusting of snow that creates panic in Central Pennsylvania clears, heading out for a test drive.
Email is
Old January 6th, 2015, 10:14 AM
transientmechanic
1972 SIII
Thank you Trevor!
My current project; Project 90-3 diesel_jim Truck Build-up's & Restores 2 June 15th, 2013 04:22 PM
My British car project for your British Series project? corrigan For Sale - Vehicles 9 April 27th, 2013 02:10 PM
My current project; Project 90-3 diesel_jim Truck Build-up's & Restores 5 April 23rd, 2012 06:32 AM
» Defender Registry
248
xjahx
The Mule
crash05
Add your Defender
