Removing hand start dog - Defender Source
Old March 3rd, 2013, 08:40 PM
61rover's Avatar
61rover
John Crouse
I need to remove the starter dog on the front end of the crank shaft in order to replace the front crank seal. The engine is out of the truck. What's the best way to keep the crank from turning without damaging anything? Ideas?
Old March 4th, 2013, 06:38 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Large flat tip against the teeth on the flywheel on the rear of the engine? Or really lazy just use an air impact wrench and it should just come right off. Of course hit with your choice of lube if you want.
Old March 4th, 2013, 06:45 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Interogrative: it it LH or RH thread? Impact or a large socket hit with a hammer for shock. Heat and lube helps.
Semper Fi!
Old March 5th, 2013, 12:59 PM
jac04's Avatar
jac04
Jeff
Currently Roverless
Standard righty-tighty. I always use an impact for removal.
Old March 5th, 2013, 01:03 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
I need one for my 3.5 V8 if anyone wants to get rid of it.
MUDSUX
Old March 5th, 2013, 02:33 PM
61rover's Avatar
61rover
John Crouse
Thanks for the suggestions. Need to find an impact socket that size. Seems like around 1 - 5/8 or 1-11/16. Will also try locking with the flywheel.
Old March 5th, 2013, 02:53 PM
I bought one for $25 or so when I had to do this. IR2131Ti impact gun and it zipped right off.
Old March 5th, 2013, 03:23 PM
61rover's Avatar
61rover
John Crouse
Do you remember where you found it?
Old March 5th, 2013, 03:34 PM
Sears online I think. It was impact grade and deep.
Old March 5th, 2013, 07:53 PM
61rover's Avatar
61rover
John Crouse
Which size did you go with?
Old March 5th, 2013, 09:30 PM
I am not sure. Sorry.
Old March 6th, 2013, 08:50 AM
jac04's Avatar
jac04
Jeff
Currently Roverless
The only place local that I could find the socket was at Tractor Supply. Forgot what size - it was some time ago.
Old March 7th, 2013, 10:43 AM
61rover's Avatar
61rover
John Crouse
Got it. There's a new tool store next to American Furniture in Thornton. They had an excellent selection.
Old March 7th, 2013, 03:04 PM
So for future reference, what size is it?
Old March 7th, 2013, 03:16 PM
61rover's Avatar
61rover
John Crouse
I went with 1-11/16. It's a little loose so 1-5/8 might have worked. I would have bought both but I had to pay $30 for it.
dog, start, vin
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
Removing Rear Step Bumper TurkD90 Defender Technical Discussions 16 July 20th, 2008 09:42 PM
Removing ignition switch crobinson Defender Technical Discussions 5 January 3rd, 2006 06:33 PM
Removing LE Checker plate - Need help removing killer adhesive JimC Defender Technical Discussions 4 December 6th, 2004 07:24 AM
Wet Dog Campbell Misc. Chit-Chat 0 September 29th, 2004 08:27 AM
