Rear Output Flange Speedi-Sleeve? - Defender Source
Old August 24th, 2015, 02:09 PM
LR Max
Thomason, Max
1973 Series 3 109
I'm trying to find the speedi-sleeve part number for a Series (non-V8) transfer case output flange. Mine is grooved pretty bad. Since new flanges are NLA, I took mine to a machine shop to get it sleeved. He can't find the appropriate one so that is throwing a wrench into everything.
Thanks for any info!
Old August 24th, 2015, 02:44 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
If there's one that fits a machine shop should be able to measure the OD of part of the flange the seal rides on and look it up in the SKF catalog, http://www.skf.com/binary/26-128020/...edi-Sleeve.pdf , or online. If he can't do one or the other I'd find a new machine shop.
Otherwise I would assume there isn't one that will work.
If needed, I can dig out a flange later today to measure if someone else doesn't do it first.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 24th, 2015, 02:58 PM
LR Max
Thomason, Max
1973 Series 3 109
The issue is the length of the Speedi-Sleeve. He says all of the ones in the book are too short.
So there might be an "install" component missing here.
Old August 24th, 2015, 03:31 PM
ezzzzzzz
Mark Garrenton
I've installed sleeves on longer yokes using an appropriate piece of plastic or metal pipe. This is not a totally uncommon problem. The only issue is assuring that there are no burrs that could damage that finished surface.
Old August 24th, 2015, 05:02 PM
LR Max
Thomason, Max
1973 Series 3 109
So did you cut the cap end off the sleeve?
Old August 24th, 2015, 05:04 PM
Antichrist's Avatar
Antichrist
Tom Rowe
If he means the installer is too short, then yeah, he can just use a piece of pipe of an appropriate ID. That's all the install tool really is anyway, though one end is closed. The sleeve itself doesn't need to be very long at all.
Take it to Applied Industrial Services in Tucker. They can measure it and sell you the appropriate Speedi-Sleeve and you can install it yourself. Applied Industrial is pretty good, I get a fair bit from their Lithia Springs location.
Bearings and Drives Inc in Hapeville probably has them as well.
The link I provided has the installation information in addition to sizes and part numbers.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 24th, 2015, 05:11 PM
LR Max
Thomason, Max
1973 Series 3 109
Tom,
Thank you. The flange is at B&W automotive right now. I'll go pick it up tomorrow at lunch and go find them. Google says they moved to Norcross. Most interesting.
If they offer install services, I'll just get them to pop it in. Otherwise I might have to try and call in a few favors.
Thanks!
WTB output flange JimC Wanted 5 December 9th, 2008 12:38 AM
DII Front output flange weissbrewer Wanted 5 August 20th, 2007 12:40 PM
DiscoveryII Front Output flange Davis Wanted 0 August 5th, 2007 01:20 PM
Disco II output flange Davis Wanted 0 June 13th, 2007 11:56 PM
LT230T Front Output Flange questions...... kiphartzell Defender Technical Discussions 20 March 2nd, 2006 08:17 AM
