Rear jump seats - Defender Source
Old September 10th, 2011, 06:12 PM
bcourtney's Avatar
bcourtney
Robert Courtney
1973 Series III 200TDI
Rear jump seats
I bought these jump seats for my Series and I can't figure out how to make them work. I have tried the seat bottom hinge bracket both ways and move forward and back and still can't make them fold up with the back cushion in place. No matter what the fold down leg only keeps the bottom level if it is straight up and down instead of back against the tub like I have seen in others. Also the back bracket only lines up with the top rail if I hold it up off the fender well. None of the holes line up with the original, however it is a tub of a IIA so not too concerned about that.
Any thoughts?
ID:	41888   Click image for larger version
ID:	41890   Click image for larger version
Old September 10th, 2011, 10:59 PM
James Pierce's Avatar
James Pierce
James Pierce Jr.
You have the bracket attached to the seat up side down. See attached pic's. These are all the pic's I have on hand but I can take more tomorrow if this doesn't get you going. You can even see the indention from the bracket in the vinyl on the side of your seat in pic 3 and 4.
ID:	41908   Click image for larger version
Old September 11th, 2011, 02:46 AM
bcourtney's Avatar
bcourtney
Robert Courtney
Well damn that certainly explains a lot, thanks the only thing I did not try. Built a whole truck and was thrown by the simplest thing.
Old September 11th, 2011, 11:11 AM
bcourtney's Avatar
bcourtney
Robert Courtney
Where does this bar go?
ID:	41913   Click image for larger version
Old September 11th, 2011, 01:00 PM
James Pierce
James Pierce Jr.
On the back of the front seat two seats.
Old September 11th, 2011, 01:12 PM
bcourtney's Avatar
bcourtney
Robert Courtney
Got it only have two that's what threw me off. Should have 4 but only installing 2 seats right now
Old September 11th, 2011, 02:11 PM
James Pierce
James Pierce Jr.
They only go on the front two seats to line up with the holes. The rear two backs do not use them. They line up without the bar.
Old September 11th, 2011, 07:51 PM
bcourtney's Avatar
bcourtney
Robert Courtney
That makes sense as I installed the rear ones without them. I also noticed what looks like spacers on the bottom of the uprights which mine did not have but I came up with some.
Thanks for the help
ID:	41929   Click image for larger version
Old September 11th, 2011, 08:02 PM
James Pierce
James Pierce Jr.
I don't remember spacers... There were some spacers between the side of the tub and the back bracket but that was to keep them from crushing the plastic molding around the SW window. Might be a difference between Series and D90?
Glad you got them figured out. Truck looks good!
Old September 12th, 2011, 03:13 PM
Tub on a 90 and an 88 are different heights from the capping down to the wheel well flat part.
Old September 22nd, 2011, 07:06 AM
rockstardave's Avatar
rockstardave
Dave Dulansey
1995 D-90
I wanna see more pics of the truck and build!!
jump seat, seats
Side Facing Rear Jump Seats PDX Bolt Wanted 1 October 21st, 2009 05:30 PM
rear jump seats for my 95 Hazard Wanted 3 June 9th, 2009 11:43 AM
Jump seats and bench seats nmc Defender Technical Discussions 3 April 16th, 2006 10:54 PM
D-90 Seats (front and rear Jump) arbik Wanted 2 January 31st, 2005 01:04 PM
Wanted: 2 rear jump seats dmb Wanted 0 January 30th, 2005 11:29 AM
