Radiator Cap - Defender Source
Old May 21st, 2013, 11:34 AM
mgyip
Matthew
1972/Series 3 88"
Radiator Cap
I get the feeling my radiator cap is weak. When I obtained my 88, there was no coolant in the upper hose - we refilled it and it holds coolant without an issue. I finally was able to take the 88 for a drive and when I returned, it was peeing coolant on the floor. A check after it cooled down and there's no coolant in the upper hose again. I don't see any other obvious leaks so I'm thinking that the cap is weak.
That said, what is the pressure for the cap? I hate to order a $8 cap from an LR-specific shop then pay $15 in shipping when I can buy a $10 cap locally - that is unless, like my VWs, there is something special and mythical about using the OE part.
Old May 21st, 2013, 11:41 AM
The Dro
Dro
1988 Ninety
Is your overflow bottle full? Perhaps what you are seeing is the excess of coolant out of the overflow.
Old May 21st, 2013, 12:00 PM
ranewman's Avatar
ranewman
Rick Newman
85 Defender 110
From what I'm seeing 16 lb. DON'T get one with the plastic release if you can help it. Trust me.
Rick
06 L322 Range Rover "The Black Pearl"
06 L322 Range Rover "2.0"
97 Disco SD "Emma" (250k and going strong)
95 P38 "Gus" RIP
99 P38 Callaway Edition #106 RIP
85 Defender 110 2.5NA "Margret"
01 D2 SE7 "Cuzn It" (blown up POS)
03 D2 SE "Fred"
Hoarder of 2.5 NAD parts
"In God we trust. Everyone else keep their fucking hands where they can be seen."
Old May 21st, 2013, 12:55 PM
mgyip
Matthew
1972/Series 3 88"
The overflow isn't full, per se but as the engine cools down, it's not drawing the coolant back into the system so it's low.
Rick - thx for the tip. 16 psi it is...
radiator
