Pull knob function - Defender Source
Old January 9th, 2015, 07:00 PM
WildBoar's Avatar
WildBoar
Derek Borror
109 withdrawals filled by a 110
Pull knob function
Green bible not much help with helping me identify what the pull knob (with the fancy tape) does for me. What does it do for me!
"I think we are good...its still dripping"
Old January 9th, 2015, 07:18 PM
the rover shop
shayne young
Since it has the detente in it, it is meant to be in different positions.. So it's either a choke cable..on a gas engine.. Or a fast idle on a Diesel engine..
Old January 9th, 2015, 07:21 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
I think it has something to do with the Wonder Twins...
Attributed to Shayne...
Old January 9th, 2015, 07:28 PM
WildBoar's Avatar
WildBoar
Derek Borror
Thanks Shayne. Kevin....wonder twins?
Old January 9th, 2015, 07:29 PM
Lemonhead
TB
1997 D90 SW
Heat!
That's why I've been told.
Have the same on our IIa.
It's connected under the hood but doesn't appear to change the temp all that much.
Old January 9th, 2015, 07:31 PM
Lemonhead
TB
1997 D90 SW
BTW
From what I can tell, this may be exclusive to NADA models.
Old January 9th, 2015, 07:55 PM
An easy way to tell would be to have someone pull it in and out while you look under the hood to see what's moving.
Old January 9th, 2015, 08:03 PM
Lemonhead
TB
1997 D90 SW
http://forums.roversnorth.com/showth...A-heater-valve
Old January 9th, 2015, 10:48 PM
WildBoar's Avatar
WildBoar
Derek Borror
Thanks! Yep...heat related...does not make much of a difference at all though.
Old January 9th, 2015, 11:00 PM
WildBoar's Avatar
WildBoar
Derek Borror
It's bizarre that it needs to be pushed in for heat. Seems a bit odd and in the way when you don't want "Heat"
report function only for pm's ? Uncle Douglas Support & Suggestions 6 January 5th, 2012 12:01 PM
Radiator Oil Cooling Function dsh12 Defender Technical Discussions 3 May 16th, 2010 01:47 PM
heater intermittent function snosrfr Defender Technical Discussions 6 February 14th, 2010 06:13 PM
Dome Light / '97 Multi Function Unit GYM Defender Technical Discussions 2 March 6th, 2007 05:53 PM
OME spring set-up by intended use- used search function lactic Defender Technical Discussions 5 October 14th, 2005 01:22 PM
