Problem shifting gears - Defender Source
Old December 28th, 2011, 07:39 PM
red64chevelle
Daniel Smith
86 110 300TDI,16 Disco Sport
So, I have been driving the Series around (without the OD now) and have developed a problem. Sometimes it will not want to go into first or second, and sometimes after going through first and second, it will not go into third or fourth. Although the shifter is moving about, it is really just stuck in second.
Are there any parts to replace, or adjustments I need to make?
Thanks in advance.
Old December 28th, 2011, 09:47 PM
LRover's Avatar
LRover
J. Michael McCaig
if I remember right, the Series 3 has a nylon ball at the bottom of the shifter that can come off allowing the lever to move around a lot and preventing you from getting it all the way in gear. From what you describe that may be the problem. You will probably have to remove the tunnel cover to check it. Also check your clutch adjustment and gearbox oil level.
Old January 1st, 2012, 07:08 PM
red64chevelle
Daniel Smith
It was the shifter. The ball at the end was worn so that when I was going from 2nd to 3rd, it was jumping over without shifting out of 2nd.
Either way, a new shifter is on order, and until then I know how to shift it without failing.
Difficulty shifting gears martym Defender Technical Discussions 3 November 4th, 2006 04:38 PM
94 shifting problems jstrong98 Defender Technical Discussions 6 January 26th, 2006 03:06 PM
Gears vs Tires jimbemotumbo Defender Technical Discussions 21 April 26th, 2005 09:23 AM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
