Pinion Seal Question - Defender Source
Old April 4th, 2016, 09:09 PM
RBBailey
RBBailey
1965 IIa
Need to replace the seal, but is there too much play in this to ignore? Or is this just normal driveline slack? It seems to have a tiny bit of lateral movement, no longitudinal movement, but some rotational slack that can be heard.
Video: https://www.flickr.com/gp/bhcmbailey/Br98WU
Project:
1965 IIa SWB
Old April 4th, 2016, 09:15 PM
Rotational slack is normal, it is just the backlash in all the gears and splines combined.
Assuming the nut is tight, there should be no bearing play. It is meant to have preload on the bearings.
Old April 4th, 2016, 09:18 PM
RBBailey
RBBailey
1965 IIa
I'm guessing this is OK...?
Video is public now.
Project:
1965 IIa SWB
Old April 4th, 2016, 09:25 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Yeah, that doesnt look too bad...
Not the leaky seal, that is terrible...but your amount of play is ok.
Rent my
Old April 4th, 2016, 09:27 PM
Looks okay. That is an very small amount of rotational play. You have a tight driveline.
Have a look at the flange when you do the seal. If it is grooved at the seal surface, it will probably leak again.
Old April 4th, 2016, 09:47 PM
RBBailey
RBBailey
1965 IIa
Understood. Thanks.
Project:
1965 IIa SWB
Old April 18th, 2016, 01:41 PM
Commando II
Chris tidwell
1988 Defender 110
Pinion Seal Replacement
Should I replace the Flange when I replace the Pinion seal as a precaution?
Old April 18th, 2016, 02:00 PM
Commando II
Chris tidwell
1988 Defender 110
Don't know yet. Ordering parts now...Just wanted to know if I should replace at the same time but guess I won't know till I pull it apart.
Need to change diff Oil as well. Any recommendations?
Old April 18th, 2016, 02:04 PM
Can't hurt. They are not expensive. An gear oil is fine.
Old April 18th, 2016, 02:16 PM
Commando II
Chris tidwell
1988 Defender 110
I will order both...Parts take time to get here. I agree, would hurt.
Old April 18th, 2016, 02:29 PM
Ordered a Speedi Sleeve yesterday for my leaking pinion.
Old April 23rd, 2016, 05:31 PM
RBBailey
RBBailey
1965 IIa
I have FINALLY had a chance to get under the truck and get this seal worked on. I had to take it to a shop to get the nut released after trying every trick I could think of.
But now I can't get the seal out. I'm carefully using a screwdriver to try to pry it out, but it is not budging in the least.
Any pointers?
Project:
1965 IIa SWB
Old April 23rd, 2016, 05:40 PM
You can snip away at it with some wire cutters but be careful not to mar the metal sides.
Old April 23rd, 2016, 05:54 PM
Big screwdriver or pry bar and push hard. No need to be gentle.
Old April 23rd, 2016, 05:59 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Self taping metal screw
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old April 23rd, 2016, 06:03 PM
RBBailey
RBBailey
1965 IIa
Well... I'm certainly not being gentle. Just trying not to ruin anything else.
Project:
1965 IIa SWB
Old April 23rd, 2016, 06:14 PM
If it is not out you are being too gentle. The seal has a metal outer so it is quite hard to hurt anything.
Old April 23rd, 2016, 06:27 PM
I would you a seal removing tool. You could get one at any auto parts store.
Old April 23rd, 2016, 07:01 PM
RBBailey
RBBailey
1965 IIa
I think I'm going to have to pull the flange apart at those six bolts and use a vice and a hammer to pound it out from the inside direction. This just isn't working.
Project:
1965 IIa SWB
Old April 23rd, 2016, 07:11 PM
Huh?
Pinion Seal Leak, Salisbury Diff Doug Defender Technical Discussions 18 August 8th, 2016 03:07 PM
Rear Pinion seal question squidface Defender Technical Discussions 6 March 8th, 2016 06:26 PM
pinion nut torque specs and seal question wantone Defender Technical Discussions 0 May 30th, 2012 12:11 PM
Rear pinion seal bjf Defender Technical Discussions 7 April 13th, 2012 01:57 PM
Sals. pinion seal D90user Defender Technical Discussions 0 March 15th, 2007 01:01 AM
