PCV Valve diaphram cover - Defender Source
Old January 4th, 2012, 03:59 PM
cabell's Avatar
cabell
Cabell Crowther
I seem to have lost the round metal covers that go over the diaphrams on both of my series trucks. I can't find them other than by purchasing the entire valve assembly. Are they just round discs that I could fab up or are they more invloved?
Old January 4th, 2012, 07:10 PM
They are quite bit more involved. Not only are they round but they have a small hole drilled in them as well.
You might want to farm that part out.
Old January 5th, 2012, 11:22 AM
cabell's Avatar
cabell
Cabell Crowther
So what would be the disadvantage of skiping the valve and tying into the intake hose between the air filter and carb? Too much suction?
Old January 5th, 2012, 11:29 AM
rdavisinva@yahoo.com
Old January 5th, 2012, 11:45 AM
the PCV valves are designed to close at idle and during other periods of high vacuum. That prevents a large vacuum leak at idle. During the application of throttle when vacuum is lower and crankcase pressure is rising, the pressure of the crankcase gasses pushes the PCV valve open and alllows the blow-by gasses to be burned in along with the air fuel mixture.
you should be able to use any inline PCV valve. Just make sure it goes the right way around and check it often because they do start to leak, not sure why but they do.
Old January 6th, 2012, 08:27 AM
cabell's Avatar
cabell
Cabell Crowther
Thanks Dave. I'll check out the inline units.
cover
200tdi valve cover bolt gasket problems dave_lucas Defender Technical Discussions 15 November 16th, 2009 06:49 PM
valve cover photos rover4x4 Misc. Chit-Chat 4 February 6th, 2006 06:06 PM
Disco Axle, Tire Cover, D-90 top, D-90 rear seat, Safari Gard Bumper m016324 For Sale - Parts 17 January 4th, 2006 09:20 AM
4.6 Valve Cover tbutzow Wanted 2 January 28th, 2005 02:18 AM
broken valve cover bolt...help!!!!!!!!! erik d Defender Technical Discussions 2 November 10th, 2003 03:12 PM
» Defender Registry
Rupert
REDrum
Defender
JAG
Add your Defender
