Parabolic springs or Original leaf springs - Defender Source
Old May 27th, 2011, 11:39 PM
Arrington
Jason
series II 1966
Hello,
I am looking for some help on what springs to use. I am up in the air on redoing my original leaf springs or buying a set of parabolic springs. I have a spring guy that can redo original leafs that has been doing it for over 40 years. He knows his stuff very well. But some people like the parabolic springs for smoother ride.
So should i redo my old leafs? Or buy parabolic springs and if so which place here in the states has the best parabolic springs.
My land rover is a 1966 series IIA 88 all original. Its going to be driven in a small town most of the time, and will see the mountains maybe once a year. Will eventually put roof rack on, and will not ever be loaded down a big amount.
Any help or opinoins will be appreciated thanks, Jason
Old May 28th, 2011, 08:46 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
RoversNorth, WiseOwl (Canada), I know of off the top of my head that sells parabolics. Ill let others argue the pros and cons of the two types of springs. When I finally change out my springs I am going with parabolics.
Old May 28th, 2011, 10:45 AM
1962siia88's Avatar
1962siia88
Daniel Rogers
1962siia88
Hey there:
I ran rocky mountain parabolics on my rig and was very happy with them. I had two leaf front and three leaf rears on my 88" sw.
I sold them to my neighbor who runs a truck cab on his 88" and he had rear drive shaft issues with these springs and needed to place a 2 degree (iirc) wedge under the axle to correct pinion angles.
How much does your guy charge to fix up the old springs?
Daniel
Old May 28th, 2011, 09:22 PM
Arrington
Jason
series II 1966
He told me around a 150.00 a pair.
Old May 29th, 2011, 12:55 AM
Parabolics are leaps and bounds more comfortable than stock.
Old June 1st, 2011, 12:33 PM
Troys
Troy Smith
1995 D90 SW
Jason - I replaced the springs on my 1971 SIIa with parabolic springs manaufactered by T.I. Console in conjunction with Koni shocks. Poly bushes and all. I was very very happy with the set up and ride. I had several friends who replaced their stock springs several times over the period of time I had my set up. I have since sold the truck but those same Koni shocks and T.I. Console springs are nowhere near needing replacement. My latest project is also a 1966 SIIa. I just installed Haystees (formerly T.I. Console) parabolic springs, Bilstein Shocks, poly bushes with the greasible shackle bolts from Great Basin Rovers. Hands down the finest Series suspension set up IMHO. All that to say this, parpabolics get my vote. Keep in mind that not all parabolics are built to meet the same standard.
Good luck!
Troy
original
D90 Springs... arbik Wanted 2 March 25th, 2006 10:09 AM
Stock height aftermarket springs? lmaldonado Defender Technical Discussions 3 June 29th, 2005 08:23 AM
new springs? scoloco Defender Technical Discussions 4 April 5th, 2004 06:08 PM
OME springs! TwisteD90 Misc. Chit-Chat 5 October 2nd, 2003 06:16 PM
